4.6 with H pipe and flowmaster 40 series.
Well i know that 4.6 mustangs with this setup sound really good. So im wondering if a 4.6 F-150 would sound the same, and if its even possible to do.
Yes it is possible and yes it should sound really good. Check out the supercharger section and look for a post by Flatsman. He posted a video w/sound of his new setup. It's a maganflow x-pipe and dual magnaflow mufflers. Of course his is all decked out with a charger but still the sound should be great on any V8.
If the money is available I would suggest going with an x-pipe has I think it should make the two cylinder banks mix more evenly and help retain more of the low end torque. An x-pipe will cost you around 130 where as the best h-pipe kits are under 50. Magnaflow, Spintech, and Dynomax all make one.
I plan to go to get an new system ASAP but would rather put it off till I can afford an x-pipe setup. Way I see it you get great flowing, great sounding true duals with no or little low end loss. In the other hand for the cost of an h-pipe setup you really can't go wrong either.
