How 'bout them Aggies!...?? :Borla?
how 'bout them Aggies!...??
what was the problem ((21-7)) ???? anyway, i have a question about Borla. is Borla exhaust considered a "racing" type of exhaust?? does it matter which exhaust syytem to get when it comes to racing f-150s??? help.
thanx
JP
what was the problem ((21-7)) ???? anyway, i have a question about Borla. is Borla exhaust considered a "racing" type of exhaust?? does it matter which exhaust syytem to get when it comes to racing f-150s??? help.thanx
JP
Well, the Borla like many of the others is a cat-back, so I wouldn't really consider it a racing exhaust. If I were racing (off road use only) I'd be looking at doing header pipes, no catalytic converters, and probably two mufflers -one on each side. Also, there usually is a minimum length specified for the exhaust pipe, but it would be pretty short-- exiting in front of the real wheel. Look at some websites that feature NASCAR trucks, you may find a photo or two of what they run-- it's pretty aggressive I'm sure!
If you meant strictly from the muffler design, the borla muffler itself has a single inlet and dual outlet-- you can see right through it. Kinda like the old "Cherry Bomb" mufflers. See:
Hope this helps!
Greg O.
Hope this helps!
Greg O.
