2000 Ford Expedition - Intake Noise that sounds like Exhaust Leak
Old Mar 25, 2022 | 04:50 PM
Dr. Sleep's Avatar
Any mechanics out there who can tell me what this noise is:
Background:
1. Noise seems to come from the air intake. When I take the intake off, I can hear the noise through the intake tube.
2. Noise is RPM dependent: hear it at 1000 rpm, but not lower RPMs
3. Noise is reproduceable with RPM around 1000
4. Noise started after I replaced the IAC valve and TPS. I'm wondering if a bad gasket on the IAC valve could cause this noise?
Old Mar 25, 2022 | 09:17 PM
Try removing the air intake and replace it with the stock one and see if it goes away.
Old Mar 27, 2022 | 03:00 PM
Dr. Sleep's Avatar
Hmm . . . that K&N Cold Air Intake has been on there for many years without a problem. I did recently remove and re-install it, though. So, although I don't think the stock vs K&N is the issue, maybe an air leak around one of the rubber connectors could cause this?
Old Mar 27, 2022 | 07:14 PM
Dr. Sleep's Avatar
Solved the problem. It was the new IAC that I purchased from AutoZone. It was creating the problem. I put the old one back on, and the problem immediately went away. The new part looked exactly like the old part except for 1 minor difference, the electrical connection was clocked 90 degrees counter-clockwise. The connector fit correctly, but was clocked differently from the factory part.
Old Mar 27, 2022 | 08:07 PM
Glad you got it fixed.
