0171 1st time using a scanner
Old May 5, 2021 | 02:38 PM
Foxtrot6's Avatar
I bought a 1999 f150 had an egr code, i fixed by clearing the passage ways in throttle body adapter, now i have a lean code, i havent found any vacuum leaks, but my STFTs read 25, and 32% on freeze frame (bank 1 and 2), but on live data they are both fluctuating above and below 0 what is going on there ? I have cleaned the MAS I have 30 psi at the rail, it holds when the engine is turned off
Old May 5, 2021 | 03:12 PM
Which engine? Did you check the PCV elbow behind the intake?
Old May 5, 2021 | 03:22 PM
Foxtrot6's Avatar
The 4.6 I replaced the hose above the pvc elbow tried using propane back there but I think the flow wasn't enough may try carb cleaner, I have not completely removed the pvc line to look at it.
Old May 5, 2021 | 04:15 PM
No, don't use carb cleaner. You do need to get back there and remove the elbow to properly check it. The elbow itself - attached to the intake port - rots, gets soft, and cracks and leaks.
https://www.dormanproducts.com/p-520...bow&origin=YMM
