codes P0171 and P0174 help
Old Jan 1, 2018 | 01:59 PM
jamzwayne's Avatar
~Running Lean Bank 1 & 2~
TSB
05-22-6
ISSUE:
Some 2001-2003 F-150, 2004 F-150 Heritage and 2001-2003 E-150/250 vehicles equipped with a 4.2L engine may exhibit the malfunction indicator lamp (MIL) on with diagnostic trouble codes (DTCs) P1131 and/or P1151 (system too lean bank 1 or 2). This condition may be due to leaking isolator bolts/port gaskets in the upper-to-lower intake manifold mounting area. This condition is sometimes intermittent and may not be apparent on a warmed-up engine.
~ SERVICE PROCEDURE ~
Perform a self test. If DTC P1131 and/or P1151 are the only codes stored in the powertrain control module (PCM) proceed to Step 2. If any additional DTCs are present, follow normal diagnostic procedures found in the PC/ED Manual.
Remove the upper intake and replace only the port gaskets (9H486) and isolator bolt assemblies (9S479). The new isolator bolt assemblies use a rubber material that is green in color, do not install the old isolator bolt assemblies with the black rubber material. Do not replace any other intake parts or gaskets.
This may seem irrelevant to your issue, but it just may solve your issue.
Old Jan 1, 2018 | 05:14 PM
projectSHO89's Avatar
Since he has a 4.6, not a 4.2, posting that TSB is indeed irrelevant.
