What should I replace while my intake manifold is off?
Old Apr 6, 2017 | 01:42 PM
bigmike7801's Avatar
My intake manifold cracked the other day so I have taken it off and am looking to replace anything that would be "wise" to replace while I have it torn down.
Right now I'm replacing the manifold with the Dorman 615-188 Upper Intake Manifold which comes with all of the gaskets and a new thermostat.
I also bought new spark plugs and was considering a new serpentine belt.
Is there anything else I should consider?
Is there any reason for me to replace the Curved Boot Ignition Coil at this time?
Some of the springs separated from the boot when I took them off. Is that considered damaged?
I have a 2000 F150 Lariat with the 5.4.
Old Apr 6, 2017 | 04:47 PM
You don't necessarily have to change the coils, but I'd definitely replace the boots and springs.
http://www.rockauto.com/en/parts/sta...ug)+boot,10150
Old Apr 9, 2017 | 08:49 AM
enriched's Avatar
I would changed the cylinder head temp sensor while the intake manifold is off and any plumbing that may run under there too.
Old Apr 10, 2017 | 02:37 AM
Veteran: Army
don't forget the upstream oxygen sensors...
Old Apr 13, 2017 | 11:00 AM
Ended up just replacing the spark plugs and coil packs.
