Cold Air Intake
Old Apr 21, 2016 | 09:41 AM
speedingfast's Avatar
Cold Air Intake
I am planning to purchase a cold air intake for my 2002 Ford F-150 King Ranch Crew Cab. What brand should I go for? Volant or K&N?
Old Apr 21, 2016 | 10:02 AM
Don't waste your money, you already have a cold air intake. The only gain you will have is noise since the aftermarkets eliminate the silencer. Go for a custom tune instead for any real power gain.
Old Apr 21, 2016 | 10:08 AM
Do the Gotts mod to your stock intake.
https://www.f150online.com/forums/ar...3-f-150-a.html
Old May 26, 2016 | 12:41 PM
sysman-rick's Avatar
Smile Cold Air Intake
I installed a Volant system on my 2005 F-150. I also installed a Evolution tuner from Edge products. I set it for towing mode(more agressive shifting.
Wit BOTH installed better economy,rev limiter changed,and top speed changed.
That being said,you must consider the ramifications of a increased air charge
on fuel/air mixture. Too lean may cause valve or combustion problems.
Do some research.
Old May 26, 2016 | 06:15 PM
beechkid's Avatar
25 Year Member
That's impossible because the oe ecm software will adjust the A/F up to 25%.....if you are getting an improper A/F mix, it's because of failed engineering on the aftermarket components....not unusual BTW
Old May 26, 2016 | 08:25 PM
The 5.4 3 valve (2004-2010) needs custom tunes if you install an intake due to the MAF transfer function. Without them, it will run too lean. This does NOT apply to any other engine.
Old May 26, 2016 | 09:15 PM
lmonahan21's Avatar
2010 xlt supercrew
I would definitely say go with the K&N I have had it for two years now and it works great and sounds even better.
Old Jul 25, 2016 | 04:10 PM
mgascon's Avatar
Go the do it yourself route. Very easy to do!
Old Aug 23, 2016 | 12:55 PM
Thomas Schnake's Avatar
I have a 2015 f150 5.0 and installed the AIRAID 400-293 intake. I got a yellow wrench and the truck told me it was low throttle response. Then driving through water and rain, my truck now shuts down, or the windshield wipers, or the fog lamps, cruise control stop working. I also get reduced power. Does anyone know why this is happening?
Old Aug 26, 2016 | 07:20 PM
Paul888's Avatar
Take the intake off and get your $400 back.....put the stock intake back on because it is a cold air intake.
$400??????? Good grief.
