Clarifying CAT Set Up 2002 F150
Old Jul 14, 2015 | 05:32 PM
thelariat02's Avatar
Originally Posted by w00kie13
I also have the p0403 code what would I Need to get from radio shack to bypass the code and the CEL light comming on? I want to get MagnaFlow high flow cats but money is a little tight right now as I just bought the truck.
Doesn't that code have to do with the EGR? If so clean it
Old Jul 14, 2015 | 05:33 PM
w00kie13's Avatar
Sorry had entered wrong code I meant p0430
Old Jul 14, 2015 | 07:12 PM
Do a search for Gotts O2 Mod.
Old Jul 14, 2015 | 11:22 PM
This ^
Old Jul 15, 2015 | 10:48 AM
w00kie13's Avatar
Will this work even if I have cats still?
Old Jul 15, 2015 | 04:34 PM
If you are trying to clear the code to pass emissions inspection, probably. You can even ream out the cats - which I would do if there's any possibility that they are getting clogged. Your eventual goal is to replace your 4 cat system with a 2 cat high flow system.
Old Jul 24, 2015 | 09:25 AM
Humpbackshooter's Avatar
Hotrod....can you post some pics of your set-up? I would like to try this also.
Not to be nosy, but what would your cost on this be. I see on google that some of the Maggy kits run upwards close to $1000. Then you add the PHP tuner. Just trying to see how much $ I need to save up.
Hump
