P2195 and 2010 FX2 4.6
To anyone that can help. I ran into an unusual situation today. My truck started missing then stalled on the the road today. The first indicator was oil pressure, the needle did not move and I got the diag. warning oil pressure is low. Of course the truck would not turn over. So I sit idle for a while, the check under the hood for loose contacts, hoses, burned fuses, etc. Found nothing. Figured I jacked something up, from an oil change I did the 2 days before. Called a tow truck, and while enroute, for kicks I tried to turn it over again. The engine kicked on, ran fine, but with the engine light on. I was able to drive home and the truck ran fine, other than the check engine light being on. So I got home an put on my code reader, and sure enough P2195.
This grasps me as odd, thus my post. If anyone has seen anything familiar to this, and can shed some light before I start checking hoses, and O2 sensors, etc. I would appreciate it.
I did check the other threads, and nothing familiar to this, if I did miss it please post the link.
I also found a thread on the Raptor forums, about some issues with the 2010's built before a specific date, but my truck did not fit that range.
Thanks!
Thanks!
