Muffler selection
Old Jan 1, 2012 | 04:30 PM
Akhunting's Avatar
Muffler selection
Does anyone have recommendations for a quality quiet exhaust system that will still take advantage of a less restrictive exhaust? There are plenty of threads on ways to make my exhaust louder but I would prefer something quiet for headin out to coyote stands. I was thinking of running twin pipes (with a crossover) off twin mufflers straight out the back. Anybody have any other ideas or suggestions? My current muffler is stock and quiet but about shot and in need of replacement and I wanted to put in a new system that would produce as many gains as possible while retaining the low sound volume.
Old Jan 1, 2012 | 05:13 PM
Arklight's Avatar
Why not just do a SI/SO with a 24" Magnaflow?
Old Jan 1, 2012 | 05:59 PM
Jmo371's Avatar
or a flowmaster 70 series?
Old Jan 1, 2012 | 08:01 PM
swmof150's Avatar
I had a SI/SO magnaflow on my truck before I went to duals and it was quiet under 2000 rpms.
Old Jan 1, 2012 | 08:12 PM
scobar's Avatar
I did a 24" magnaflow in place of the stock muffler. It was about $80 and not a lot of work. Not sure if your stock pipe is shot. This is very mellow.
Old Jan 1, 2012 | 08:32 PM
scobar's Avatar
Old Jan 1, 2012 | 09:28 PM
avfrog's Avatar
Don't waste your money on duals. The only advantage to duals is noise.
Do a single 24" magnaflow and be done with it.
Old Jan 2, 2012 | 02:14 AM
Akhunting's Avatar
Thanks for the feedback. I have access to a shop with an exhaust bender so cost is not really a consideration, just a bit more pipe and time to bend it. After the recommendations I will probably go the easy way though and just replace the stock system with the SISO and call it good. Thanks.
Old Jan 2, 2012 | 11:05 AM
avfrog's Avatar
^ It's not just easier, your torque curve will be lower with a siso system.
Old Jan 4, 2012 | 09:17 AM
Akhunting's Avatar
I am planning on picking up a SISO similar to the pic above in this thread. When I install it would it be better to have closer to the engine, farther away or does it have any bearing whatsoever?
Old Jan 4, 2012 | 10:13 AM
Blue07STX's Avatar
The farther back the less drone you will have in the cab. Install it as far back under the heat shield as possible.
Old Jan 4, 2012 | 08:03 PM
avfrog's Avatar
^ yep
