Reduction in Exhaust Size
Old Oct 24, 2011 | 08:40 PM
Catchad81's Avatar
The exhaust pipe on the 5.0s seems to be bigger than on previous engines. If going to do a SI/DO muffler, what would be the negatives to using a 2.25" intake, which is slightly less than the stock pipe?
Old Oct 24, 2011 | 10:55 PM
avfrog's Avatar
Reduced exhaust velocity, and possibility a loss in low end torque to some degree.
Do it right and keep it all the same size.
And it's called an inlet. An intake is under the hood.
Old Oct 24, 2011 | 11:06 PM
MossyOak3006's Avatar
Agreed. Keep it 2.5" since you're doing a SI/DO. It will sound a little deeper with 2.5" too if you consider that a good thing
