small exhaustive leak
Old Aug 17, 2011 | 09:34 AM
jerrybizzle's Avatar
My 06 f150 with the 5.4 has been throwing an intermittent code of small exhaustive leak. I have a k&n cai, flowmaster si/so 3 inch cat back and diablosport programmer. When the check engine light comes on and I try and read the code with the programmer it doesn't read any codes. I went to autozone and used on of their scanners which showed the small exhaustive leak code. They said may be the gas cap, which I tightened. I am thinking the intake. When I clear the code, it takes a couple weeks to come back. Any ideas of what it may be or similar experiences? I doubt its the exhaust as its pretty solid, but will take another look.
Old Aug 17, 2011 | 11:09 AM
ParnAZ's Avatar
We need the DTC in order to help. "Small exhaustive leak" is kinda vague.
Old Aug 17, 2011 | 12:09 PM
It's cleared now as I got the oil changed Monday but will get it next time. I also thought it was a pretty vague description. Exhaustive leak (small), is what it said.
Old Aug 17, 2011 | 07:11 PM
avfrog's Avatar
Hmm... good one there. Did you try a search on this sight? Just curious if this has came up before.
Old Aug 17, 2011 | 07:12 PM
avfrog's Avatar
I just did, and I got nothing.
Old Aug 17, 2011 | 07:35 PM
Why wont the predator pick it up? I thought those programmers could read codes.....
Old Aug 17, 2011 | 09:12 PM
They can, guessing it must be so minor that it doesn't even register on the programmer. That's the only thing I could think of. When I hit clear codes on it, it does indeed clear it out. I should have the code within a few days or so, but I think I am going to reinstall this pos k&n one more time and see if that's it. It also has a high pitched squeal at certain rpms, from the intake, which leads me to believe it may be the culprit. I put out a thread a while ago on the squeal, and a few other people have it as well. Should have done gotts, but bought k&n before I knew. Damn. Also talked with k&n and they say it is fairly common. Not the nice woosh sound, but a squeal.
Old Aug 17, 2011 | 09:21 PM
Don't ever look back....just learn from your mistakes and move forward....
Old Aug 17, 2011 | 11:14 PM
Good quote. I know, about ready to bite the bullet (230 for the intake) and just do the gotts. Better in the long run.
Old Aug 18, 2011 | 07:04 PM
avfrog's Avatar
^ Exactly
Old Aug 26, 2011 | 01:42 PM
Well my code has returned and I reread it with a different scanner. The code is P0442, evap emission control system leak. Any suggestions?
Old Aug 26, 2011 | 01:44 PM
http://repairpal.com/OBD-II-Code-P0442
Old Aug 26, 2011 | 02:04 PM
dsq3973's Avatar
They don't read all the trouble codes, my XCal would not read the trouble code for the EGR valve failure on my F350. You need something like Autoinginuity software to read all the trouble codes for OBDII.
http://www.autoenginuity.com/product...ware.html#EI01
Old Aug 26, 2011 | 03:15 PM
Thanks Mr. Bluejay. After reading that I wouldn't be surprised if it is something to do with the fuel tank fill neck. Just filled up today and the pump popped like it was full 4 times within the first two gallons. Took 20 gallons. Usually once is understandable, but this was unusual. May be something with the neck? Will read more of that link when I get some time.
Old Aug 31, 2011 | 06:40 AM
02RegularCab4x4's Avatar
OK Evap leak detected sounds better than exhaust leak detected..... Anyhow, your Evaporative emissions (EVAP) gas fumes, are to be contained in the system lines, charcoal canister etc. until they are released into the intake to be burned off. It could be a leaking gas cap, any of the lines in the EAVP system, or the EVAP pressure sensor could be bad and thinking there's a leak when there is not. EVAP leaks to me were always a pain to find so try starting with your gas cap. You are shutting the truck off when fueling right? The bottom line other than the annoying light is that the EVAP code will not cause any issues performance or driveability wise. Check the recall/tsb section on this site also......
