CEL after gotts mod
go and get yourself a can of AIR INTAKE CLEANER and start spraying around everything you took off to do the mod and listen to see if you hear the truck rev up a little bit.
listen to see if it revs up? like if when its idling it revs, then goes to really low rpm, then high? cuz it was doing that last night . and is the cleaner to look for bubbles? or just to clean?
Did you try cleaning the MAF sensor?
Mine was dirty and my truck would idle funny and sound like it was going to die. I cleaned my MAF sensor and TB and it fixed it right up. Just another suggestion to try.
I went out and looked at my Expy (4.6) and yes there is a weep hole in the air cleaner side of the air box. It's about the size you said in your PM, so that should not be an issue.
BTW any luck yet?
BTW any luck yet?
I appreciate you taking the time to look. and no I havent had a chance to work on it. gunna take it to my friends shop tomorrow morning. I need to do my plugs and stuff anyways.
you dont have to be an ***. this is how im learning. im only 19.
maybe if you would spend your time helping "people like me" instead of telling them not to even look under their hood they would get better.
and seeing as how you only have 4 posts I dont think you have read many of my threads or posts or know much about me so dont judge. I know my fair share of automotive tricks and procedures.
You know your fair share of tricks and procedures, yet you have no clue how to clean the MAF? Poor truck.
Your 2006 has electronic throttle body.
The code refers to an issue with that part's function.
Remove the plugup and reinsert it to be sure you did not hit the plug when working on your mod.
If you don't find anything, it's dealer time and they will not look favorably on your intake mod.
Sometimes air mods on these later trucks has been known to upset the AIR/ FUEL ratio and cause lean codes.
What were you looking for with that mod?
Good luck.
Good luck.
