Gotts Mod Question
Old Mar 18, 2011 | 10:36 AM
kscull70's Avatar
Gotts Mod Question
Hey,
I know what you guys are thinking, "Just search". It comes down to this, I did search and i understand completely how to do it. I am just confused on one thing.
First off I will give you some stats:
2005 4.6 STX 4x4
I do not have a tune and most likely will not have one in the near future
So my question is:
Will doing the Gotts mod cause my truck to run too lean? Should i stay away from the Gotts mod or will it be ok?
The reason i ask is when i was searching i have found people that say it is okay to do and others say it will cause me to run to lean and cause damage.
Thanks,
Kevin
P.S. It feels good to finally get to post again on here. I have not had a need to because i found everything else by searching on this forum.
Old Mar 18, 2011 | 02:32 PM
Veteran: Army
Originally Posted by kscull70
Hey,
2005 4.6 STX 4x4
So my question is:
Thanks,
Kevin
you do not have a three valve motor, so follow the write up for the two-valve motor (aka '97-'03) reset the ECM and you'll be fine
Old Mar 18, 2011 | 02:33 PM
Veteran: Army
P.S. you'd be suprised how many people ask this same question...
Old Mar 18, 2011 | 04:14 PM
kscull70's Avatar
Thank you for the answer. I know the question was asked before but on several different threads i read both answers. Some of the threads i read were from early on in the NBS. So i wanted to see what the general answer is now.
Kevin
Old Mar 18, 2011 | 04:24 PM
Veteran: Army
between Gotts2BMe, other contributors, myself and the moderaters we try to ensure the write ups are 100%
Old Mar 18, 2011 | 04:26 PM
kscull70's Avatar
Yea that makes sense. The conflicting answers i got were from threads that i got while searching not the technical articles.
Kevin
Old Mar 18, 2011 | 04:32 PM
Veteran: Army
just remember there's lots of "special fellers" 'round here, you've got be able to decifer who can trust and who you can't...
Old Mar 19, 2011 | 11:15 AM
X2....
Old Mar 21, 2011 | 10:32 AM
quackrstackr's Avatar
So what's the bottom line from you "trusworthy" fellers. (I'm sure tarajerame won't even see this since he put me on his ignore list for asking a question about tuners that he deemed unworthy)
What actual gains are seen from doing this mod? Just upper rpm hp or is there some fuel savings involved as well?
