Header Leak Question
Old Feb 12, 2011 | 10:16 AM
G.LoomisMan's Avatar
I've got an 01 f150 w/ a 5.4. I put a set of pace setter shorty headers on there and they've been leaking since day one. I first used the copper gaskets, then tried the spectre "no-leak" gaskets from summit. no success...i used the bolts that came with the headers...so im wondering what have you guys done to keep your headers from leaking? how often do you tighten the bolts, what gaskets did you use, what bolts did you use? also what have you done to stop leaks at the collectors? thanks in advance guys!
Old Feb 12, 2011 | 10:34 AM
shifty_85's Avatar
make sure its not the EGR port thats leaking.
ive used both shortys and longtubes from pacesetter neither leaked and i used bolts and gaskets that came with the kit.
Old Feb 12, 2011 | 10:41 AM
what should i do about that if its the egr port leaking?
Old Feb 12, 2011 | 10:43 AM
shifty_85's Avatar
Jbrew has a trick i forget what he did i wanna say he used telfon or something along those lines to coat the threads.
Old Feb 12, 2011 | 01:59 PM
wookie13's Avatar
could a leaky egr line cause a 171 and 174 code?
