squeaks when cold start, then noise goes away
Old Feb 11, 2011 | 11:58 PM
stevenminix's Avatar
hey i got a weird noise coming from my engine, I'm thinking its an exhaust leak possibly. When I start my truck up it makes a constant squeak like exhaust leak noise and then goes away after it warms up? does that sound like an exhaust leak symptom? sounds like its coming from an exhaust manifold on passenger side it seems, but i dunno the weird part is when it completely goes away after it warms up. So what do you fellas think?
Old Feb 12, 2011 | 12:00 AM
hardrock3742's Avatar
maybe its a belt/?
Old Feb 12, 2011 | 12:02 AM
thought of that one too but its got a new gatorback on it and pulleys are all in line
Old Feb 12, 2011 | 12:04 AM
Hmmm....too bad ur in mansfield. I work at a shop and i cuda hooked u up for free diagnosing and wholsale parts if it needed any.
Old Feb 12, 2011 | 12:15 AM
how far is grapevine from mansfield, it aint too far is it? I'm hoping one of my manifolds aint leaking. If I have to buy new manifolds I'll just buy long tubes to go with my true dual exhaust anyways.
Old Feb 12, 2011 | 12:19 AM
i appreciate the offer on free diagnosing though and wholesale parts. I come to think of it I really didnt start hearing this noise too long after my exhaust was done.
Old Feb 12, 2011 | 12:30 AM
SupercrewLightn's Avatar
Try puttin a little di-electric grease on your belt and see if it stops that. Mine sometimes squeaks when I first start it and when I put that on it stops. Only does it in wintertime
Old Feb 12, 2011 | 08:31 AM
4.6 Punisher's Avatar
An exhaust leak sound like a tick, not a squeak. If it's a constant squeak sound, it could be bearings on an accessory going bad.
Old Feb 12, 2011 | 11:00 AM
haha i guess ur right, but if ur driving ur truck you will cancel out ur discount in gas
Old Feb 12, 2011 | 01:13 PM
jgger's Avatar
Maybe clean/change your PCV valve, IDK just guessing.
Old Feb 12, 2011 | 06:36 PM
kikokiko's Avatar
Try removing the belt again and nspect all rotating parts where the belt goes to. might be a bearing in one of the pulleys.
Old Feb 12, 2011 | 09:26 PM
IR0NS1N's Avatar
Squeek that goes away is caused by a loose alternator belt. As the truck only has 1 belt and its new then I would say the tensioner is weak. Bearings make a metallic sound that gets worse with rpm warm or cold
