Cleaning throttle body bore
OK I just read in my Haynes that ur not supposed to use carb or brake cleaner spray to clean the bore. Well I did, so now what? Plus, what r u supposed to use?
This is in the Articles and How To section. It may have your answer. I think there is a special cleaner for TBs.
https://www.f150online.com/forums/ar...ttle-body.html
I would just drive it and see what hppens. Keep an eye on milage. If a problem develops, then you may need to replace the throttle body. You may get away with no problems.
I'd wheel out that coating they put in there. I used a fine sanding wheel, then a buffing wheel w/red rouge. You can top it off with a fresh wheel, then jewelers polish (white). I did it 4 or 5 years ago and it doesn't get dirty. Of coarse you need to run a good filter element. It stays shiny.
