Help with muffler size...
Old Nov 6, 2010 | 12:11 AM
dirtyd88's Avatar
Question Help with muffler size...
So I am currently running a (pretty sure) 4"x9"x18" muffler. I am/was comfortable with it when I wasn't running dumps. It was quiet when it needed to be, but was throaty when I jumped on it.
Here is my question...would going to a shorter length greatly effect the noise level of the muffler? I know the general statement, a shorter muffler is louder...blah blah, but I mean will 4" will make that big of a difference?
Also, when it comes to the oval bodies, what would constitute purchasing a 5x8 as compared to a 4x9? (other than fitment issues)
Just trying to see what all you guys think.
Old Nov 6, 2010 | 12:08 PM
avfrog's Avatar
First of all, what muffler is it?
Yes, in general speaking, the shorter the muffler the louder the muffler will be. For instance, if you have a 4x9x18 Magnaflow and you replace it with a 4x9x14, you will notice a significant difference. Interior and exterior volume will be noticeably greater.
As for the 4x9 vs. 5x8? A 5x8 at the same case length will actually be a little quieter than the 4x9. They have more volume in the case, thus, more packing material.
Hope this helps...
Old Nov 8, 2010 | 09:37 AM
dirtyd88's Avatar
thanks, avfrog! I had the feeling that's what would play into the noise level was volume.
that helps a lot.
Old Nov 8, 2010 | 09:38 AM
dirtyd88's Avatar
it's a Magnaflow muffler btw, either will be a XL or universal, just haven't decided.
Old Nov 8, 2010 | 09:34 PM
avfrog's Avatar
DO NOT get an XL muffler. These mufflers are chambered and packed. They will diminish what you are trying to accomplish with a performance muffler. Stick with the straight threw designed mufflers. They will perform and sound much better.
Old Nov 8, 2010 | 10:37 PM
dirtyd88's Avatar
so the XL line is more or less a stock replacement line from Magnaflow? Thanks for making that clear man.
Looks like I will either be getting a 4x9 or 5x8 in 18" length.
thanks for the help again avfrog
Old Nov 9, 2010 | 07:07 PM
avfrog's Avatar
