Y pipe size ?
Old Oct 19, 2010 | 01:22 PM
RobPad's Avatar
Y pipe size ?
thinking about dumping the stock exhaust in favor of a better system. my question is it better to use a 2 1/2" to 3" y-pipe or stay 2 1/2" in and out. doing a SI/SO system. using a magnaflow muffler. which y-pipe will give the most gains on the low end.
Old Oct 19, 2010 | 01:57 PM
MGDfan's Avatar
Hi.
For SISO - 2.5" IN/ 3" OUT 'Y' pipe + 3" intermediate pipe, + 3" In/Out muffler
MGD
Old Oct 19, 2010 | 02:12 PM
Uncle Jesse's Avatar
Yup, what he said.. i swapped out mine using a Magnaflow part... sounds a little deeper and seem to have picked up a bit of low-end torque...
Old Oct 19, 2010 | 02:28 PM
ParnAZ's Avatar
Can't say much for power gains cause I put LT's on at the same time but I went with the maggie Y 2.5" on both ends w/ 2.5" midpipe and works great. Exhuast sounds much better and although I have headers I think the Y has alot to do with the deeper sound.
Old Oct 19, 2010 | 07:25 PM
avfrog's Avatar
Staying with a 2.5" mid pipe with a straight threw muffler will boast your low end torque curve. I recommend getting a Magnaflow Y pipe and leaving it all 2.5" for MAX low end.
Old Oct 19, 2010 | 07:38 PM
MGDfan's Avatar
Hi.
[OT]
I just noticed something here - yer O2's may be right on the bordeline w.r.t. mounting - hard to determine the exact angle, but Innovate Motorsports (they make widebands) advises the following:
"Install the oxygen sensor’s bung upstream from the catalytic converter
(a bung and plug is included in the LM-1 kit). Any decent muffler or
exhaust shop can do this for you. The wide-band oxygen sensor is then
installed into the bung to take a reading. (Insert the plug into the bung
when not in use). The bung must be installed in the exhaust pipe at
the side or on top, NOT on the bottom of the exhaust pipe. Best
position is between 10:00 and 2:00 position
" Do NOT install the Bung below the 3 o'clock or 9 o'clock position.
Condensation can form in the exhaust pipe and permanently damage the sensor. 6 o’clock is the absolute worst position to mount the sensor.
[/OT]
Just fyi ...
MGD
Old Oct 20, 2010 | 12:34 AM
ParnAZ's Avatar
Hmmm interesting bit of info thx for the heads up. I think that the stock position of the downstreams was just about the same angle...maybe like x:13 and x:47 max. If they start failing ill definitely look into that. Been two weeks of daily mixed driving and no CEL so ill keep my fingers crossed, thx.
Old Oct 20, 2010 | 02:28 AM
jbrew's Avatar
Originally Posted by MGDfan
Hi.
MGD
With a 4" tip, now it's perfect - She'll drag house of it's foundation
http://www.troyerperformance.com/cgi...atalogno=15609
Old Oct 20, 2010 | 08:21 PM
ROUSHFAN-1's Avatar
Hi.
MGD
Exact set up I'm doing..Parts waiting on the rear floor..Gotta make it to a zaust shop...
Old Oct 22, 2010 | 03:42 PM
F 1Fiddy's Avatar
I agree with AVFrog. 2.5 inch all the way to have the most bottom end. Need to keep the velocity of the exhaust higher at low rpm to improve torque numbers.
Is that what the factory is? Or is it 2.75?
Old Oct 22, 2010 | 06:18 PM
jbrew's Avatar
If your running LT's, HF Cats or Catless, then yes.
A cat back only justifies 3" . That's what worked out best on the Dyno. You will gaine low and high.
Old Oct 22, 2010 | 08:36 PM
avfrog's Avatar
2.5" stock on an 05.
