Another muffler newbie question
Old Oct 14, 2010 | 09:23 AM
1Gunner's Avatar
...and yes I did try "search"
Is there an aftermarket muffler... or Ford substitute... that will "bolt in" in place of the stock Ford, leaving everything looking stock, but giving the truck a V8 "sound track"?
Old Oct 14, 2010 | 09:37 AM
MGDfan's Avatar
Yes.
Maggie 5x11x22 2.5" or 3" SISO (preferred)
Maggie 5x8x24 2.5" or 3" SISO
Either one will require a short piece of pipe to compensate for the garbage can size of the OEM ... and adapters to reduce/enlarge due to the 2.75" OEM pipe size ...
Be advised that you may/may not expereience some drone - only you will be able to determine if it is objectionable (it's subjective).
Also - that 2010 muffler is a straight-through design, flow well. is stainless and does not drone -
As for 'searchin' ...
https://www.f150online.com/forums/ex...w-exhaust.html
https://www.f150online.com/forums/ex...-opinions.html
MGD
Old Oct 14, 2010 | 10:14 AM
1Gunner's Avatar
Thanks MGDfan!
I found a 5x11x22 siso 3" P/N 12579
what is the pipe size on the stock system?
Old Oct 14, 2010 | 10:25 AM
MGDfan's Avatar
Thanks MGDfan!
AFAIK - on a '09-'10 5.4 it's 2.75" ...
Before I get flamed - there are other mufflers out there you may like ( Borla, etc) - you did not specify how loud you wanted it, and I assumed you wanted near-OEM levels. The shorter the body, the louder it will be.
Just steer clear of Fartmasters
MGD
Old Oct 14, 2010 | 10:54 AM
1Gunner's Avatar
Sweet Thanks!
On Magnaflow, they list a P/N 12579 and a P/N 12589.
They have the same outside specs (5x11x22) though the 79 is straight through and the 89 is offset.
any other differences? one louder than the other?
Old Oct 14, 2010 | 10:57 AM
MGDfan's Avatar
Sweet Thanks!
No sir - just fitment...
MGD
