MagnaFlow 2005 F-150 4x4
Yes 14" Maggies and 2.25" Pipe. I wanted to get rid of the Y and just have straight pipe. SS tips.
The sound is great you can hear it if you get on it and no noise while cruising. Not sure on any power increase. I have only drove the truck back to the house since installed and it's sitting in the garage now on this nasty rainy day in Pensacola, FL.
I guess not? What is a cross over?
Edit... Looked up cross over -- > http://www.magnaflow.com/02product/02xypipes.asp
They just piped each one separate. Here is a Pic
Where they cut the y-pipe and made them straight back separately, if they installed an x - pipe and then continued individual pipes off that you would get much better low end power, and better sound.
Without the x-pipe your missing out, lol!
Is that the best place to put it right where the Y was?
Yep. As close to the front as possible.
Yer shop should have advised you on the X-pipe. No mandrel bends either, I see.
What's the shop's name & location, so others will know whom to avoid.
MGD
You can pick up a good stainless X off of ebay or you pick up a Magnaflow X from PP with the code "clubgp".
http://cgi.ebay.com/ebaymotors/T304-...Q5fCarQ5fParts
http://www.performancepeddler.com/de...CT_ID=MAG10791
I wanted all Magnaflow parts on mine, so I went with the expensive one.
