headers installed now no throttle response
so i finished the header install tonight so when i went to start it up it started just fine but the idle isnt quite right and when i go to give it gas theres nothin there. the gas pedal goes to the floor and theres no throttle response. anybody have any idea what might be causing this?
Did you reset the PCM? Disconnect Neg battery cable wait a few minutes and reconnect. O2 sensor wires or damaged sensor? Improper installation causing leak at manifold?
You almost have to of missed something here... I'm not sure what.
Almost sounds like something with your MAF sensor.
Last edited by avfrog; Aug 26, 2010 at 07:14 PM. Reason: Almost sounds like something with your MAF sensor.
