New Intake?
New Intake?
I am in the process of rebuilding my 5.4 99 Expediton EB and I was thinking of replacing my stock intake manifold with a Sullivan manifold and Cobra style trottle body adapter. My main question is will this intake work on the 99 motor or is this overkill? I'm really just looking for a little more low end power and I really don't like the wimpy looking throttle body that is on there now. My performance plans also includes headers and I'll berunning a aftermarket HD exhaust system and a Diablo tuner.
Is there a stock intake, maybe off the Navigator motor that uses the Cobra style throttle body? Thoughts and suggestions would be appreciated.
Ernie
Ernie
There is only 1 aftermarket intake manifold for the 5.4L that I am aware of, its the HPS intake manifold. The navigators have 4v heads and their intake manifold will not bolt up.
To answer your question, No.
If you are really looking to upgrade, the HPS lower with a ported upper and 75mm throttle body would be your best option in my opinion.
Ernie
Ernie
so you are building a 32 valve motor and you want to remove all low end torque from your vehicle??
since you have a 2 valve (16 valves total) just keep the stock intake manifold or use the HPS 5.4 intake
if you want to be creative
you can use a lightning upper plenum on it but a custom tune will be needed to make it run as good as possible and then you can use the lightning/harley truck air inlet systems
the intake you are loooking at is for a 32 valve motor that is being revved over 6000 rpms each and every time...
that is a upper plenum off of a Lightning and a metal intake manifold off of a '99 PI 5.4
Ah I see what you did. Wouldn't using the HPS be a better choice for me though. It seems that even with building an adapter your still restricted by size of the inlet on the manifold.
There are better ways to achieve more low end torque than swapping out intake manifolds.
LT headers
Gears
Various other bolt ons
A HPS manifold would only be good if you were planning on racing.
LT headers
Gears
