long tube headers for 97 f-150
Old Aug 2, 2010 | 02:23 PM
outlawbred's Avatar
does anyone know about any longtube headers for a 97 f-150? im about to redo my exhaust system and they are better than shortys i just cant find any
Old Aug 2, 2010 | 02:45 PM
jbrew's Avatar
Use the search bar here.
Pacesetters
OBX
Dyna tech
Search this forum, - all kinds of info. Also, you may have to order some for a 99. There all the same, -it's just that most manufacturers don't list the 97,98 for some reason. The exhaust ports are all identical for the two valves.
Old Aug 2, 2010 | 02:53 PM
Veteran: Army
since we can see thru the internet at your truck and we can tell which engine you have, I figure you can look thru the internet at what we have
(basically, we can't help you if you aren't willing to help us help you after you've used the search feature)
Old Aug 2, 2010 | 02:57 PM
offroadn'98's Avatar
The pacesetters are tricky(PITA) if you have a 97 4.6
Old Aug 3, 2010 | 03:43 AM
Veteran: Army
since you have the 5.4
OBX long tubes...
/thread
Old Aug 3, 2010 | 11:33 PM
JASON'S98S/C4X4's Avatar
Are the OBX Long Tubes easier to install than the Pacesetters?
Old Aug 3, 2010 | 11:53 PM
tarajerame seems to think so. im not sure. ps's are cheaper i believe. i had to beat the **** out of one of my primaries on the drivers side (can't remember which one) 3rd primary i think? because i couldn't even slide the bolt in cause the primary was at such a sharp angle. i don't know if thats ez to understand the way i put it. They do the job but that might be why they were so cheap. They might should put a label on them (may require some massaging) lol. So you might wanna try the obx if you can afford it
Old Aug 4, 2010 | 12:22 AM
shifty_85's Avatar
i dont know what happend with yours but mine when on just fine. as well as my buddys in his 97 expy. we had a new motor in and had the headers bolted on in under 2 hours
Think you just got the wrong set or somthing i rember you havin all kinds of trouble.
Pacesetter= made in USA but carbon steel 16GA.
OBX= made in china Stainless steel but have heard the welds on colltors crack.
Dynatech= made in USA stainless steel but VERY VERY expensive
i went pacesetters and painted them with high temp paint and called it a day.
Old Aug 4, 2010 | 09:28 PM
avfrog's Avatar
^ Sounds like a good plan right there.
Old Aug 4, 2010 | 11:18 PM
shifty_85's Avatar
got some brake cleaner and a wire brush to strip off the pacesetter paint then painted them with VHT and cured them on the truck. you can also cure them in the oven my buddy did that with his expy headers. they came out sweeeet lookin.
i just like some good ole american steel for headers you can keep that chinesse crap
Old Aug 4, 2010 | 11:22 PM
avfrog's Avatar
^ Is the paint that they come with not any good?
Old Aug 4, 2010 | 11:23 PM
shifty_85's Avatar
has a sticker right on one of the primarys "THIS IS NOT HIGH TEMP PAINT!"
i left it on my shortys the paint melted off and the headers were rusted within about 2 weeks if that.
Old Aug 4, 2010 | 11:25 PM
avfrog's Avatar
^ Ah... If I ever get LT, I'll be doing that. I wonder how long that high temp paint will last.
Old Aug 4, 2010 | 11:31 PM
avfrog's Avatar
Check this out. 1600-2000*F paint!
http://www.hirschauto.com/prodinfo.a...ber=EMPT-SPRAY
Old Aug 4, 2010 | 11:36 PM
shifty_85's Avatar
this is what i got. same color and everything. 2 cans did the set. and i have half a can left over
http://www.summitracing.com/parts/VHT-SP106/
because i didnt cure mine right the primarys have some rust on them but both collectors still look like fresh paint. the salt and snow and rain of Michigan have done a number on the primarys.
