Removed 'air silencer' Need Help
Old Mar 12, 2010 | 02:38 PM
canadian_screw's Avatar
I have the day off today and I decided to remove the tube that runs through the elbow on my intake. I wound up dremeling it out. Here is my problem, I accidentally dremeled a small hole in the elbow. What is the best way to seal it back up? Right now I have it wrapped in electrical tape. Truck runs fine no engine light or anything. But I know that this can't be a permanent solution. On the plus side, the pedal feels a little peppier, and wow it was a PITA to get all the little plastic shavings outta there. Any help is appreciated
Old Mar 12, 2010 | 02:40 PM
O and not that it should matter, but it is a 4.6
Old Mar 12, 2010 | 02:46 PM
it wont be pretty but i would probably use epoxy and a small piece of plastic to cover the hole, then use some silicone over it to make sure its sealed tight.
and yes an unmetered air leak will cause a lean condition
Old Mar 12, 2010 | 02:47 PM
Its on the bottom of the elbow, so it don't have to be pretty haha
Old Mar 12, 2010 | 03:42 PM
sgerry's Avatar
JB weld putty. Love the stuff.
Old Mar 12, 2010 | 04:25 PM
All Fixed! epxoy and silicone, with a piece of plastic from the silencer. Thanks guys!
