K&N Cold Air Intake...
Old Aug 19, 2011 | 01:28 PM
timmypstyle's Avatar
Originally Posted by Yogi.kudos
Mine does the same thing. I can only hear it if I roll down the window.
I like it though and sometimes I just roll down the window to listen to it
i have an 08 4.2 with an intake made for an 04 heritage f150 4.2L. had to rig it to work but it also whistles but only like 2500-4500rpms and at about half throttle. and if you suddenly hit the gas you hear a short whistle like a chirp.
Originally Posted by D4rK_An1mA
I've had my K&N CAI on my truck for the past 2 years, and last week it started whistling between 1200-2400rpm.....
No idea why
has it been cleaned lately? after i clean mine on my 4.2L it sounds different. you can hear a loud sucking noise till it gets a little dirt on it, then it whistles more.
Originally Posted by mitchellrg
Well, I have tried to seal up the K&N heat shield to try and redirect the noise but to no avail. Im not ready to spend $300 on a larger throttle body so for now I just turn the stereo up.
my 04 4.2L which my intake was made for, sealed to the hood with the heat shield and i had no whistle, its now on my 08 4.2L and it whistles but i couldnt use the heat shield on it since the fenders are wider on my 08 than the 04 heritage was.
Old Aug 19, 2011 | 07:09 PM
avfrog's Avatar
You know, my cheap K&N kit makes almost no noise at all. I kind of would like to of had a little more throaty sound from it, but it doesn't squeal or whistle either.
Old Aug 20, 2011 | 04:19 PM
mine definitely sounds more throaty. actaully on both the 04 and my 08. but the 08 sounds a lot better than the 04 did IMO. the 08 has a bigger diameter exhaust, its a 2.75" and the 04 i believe was a 2.5"
