Pre 97 intake.
Old Feb 23, 2010 | 10:20 AM
OREGONMUDDER's Avatar
Pre 97 intake.
Hey, I was wanting to put a cold air intake on my 96 F 150, the stipulation on some is to only install if I have a Large MAF sensor. How can I tell if it is the large or the small?
Old Feb 23, 2010 | 08:11 PM
avfrog's Avatar
^ If it is the stock one then it is "small". If it is an aftermarket then it will most likely be larger than the stock one. You can still run a CAI and benefit from it though. It just won't be quite as substantial as if you had a larger MAF. The larger MAF has a larger inside diameter to allow for more air flow.
Old Feb 23, 2010 | 08:47 PM
Thanks, IT says only fit if it has a big maf so maybe I will swap it out. thinking though i might try a different CAI. But thanks for the info.
