Catalytic Converter problem, P0420
About a week and a half ago I noticed my truck making a disturbing noise underneath the truck, sounding like metal banging up against metal.. after a few days, the noise stopped and then my check engine light came on... I went to go get it checked and it gave me this code p0420, catalyst efficiency below threshold for bank 1... am guessing it is my cat... am thinking of getting one from a junk yard,, I went to go check out the local autoparts stores and no one carries it... except NAPA AUto parts, which they gave me a quote of $509 for that.... has anyone replaced one of these???
what do ya suggest??
my truck only has 60,XXXmiles
take it to the dealer i just had mine replaced with 25k on it. it took a week and a half to get it. emissions should be covered to either 80 or 100k. make sure to remove any programmer prior to taking it in...
U have correct description of code... heres possible causes-
Use of leaded fuel
Damaged HO2S
Malfunctioning engine coolant temperature sensor
High Fuel Pressure
Damaged exhaust manifold
Damaged catalytic converter
Oil contamination
Cylinder misfiring
Downstream HO2S wires improperly connected
Damaged exhaust system pipe
Damaged muffler/tailpipe assembly
Retarded spark timing
Leaking fuel injector
Use of leaded fuel
Damaged HO2S
High Fuel Pressure
Oil contamination
Cylinder misfiring
I am leaning more towards the catalytic converter on that... also today my 6th cylinder misfired.. I saw my check engine light flash and got it checked and they gave me those 2 codes, p0420 & p0306
..I'll get that checked out at the dealer, I am a second owner of this truck, bought it used @ 35500, just hit 60k .. thanks for all the help!
The truck drives like normal. It does have the diesel sound though that many have. So I don't know if this has anything to do with it
