Wet vs. Dry CAI
Fare enough... But dont always believe the dyno results posted by the manufactures or even the TV shows.. The manufactures have only one goal - to get you to spend your money on their product... And the TV show's are all sponsored by the manufactures... They are not going to bite the hand that feeds them...
The only way to know for sure is to take YOUR truck to a shop and and have a dynomometer test run on it before and after installing your mod... How many guy's actually do this..?
By the yaw, dyno runs is not that accurate. I have read an article about how a dyno shop can give you + or - 25 to 50 % on yore HP. The variables are too many to control all (Ambient Temp, Ambient Pressure, Engine Temp… etc).
I agree with the Idea that CAI will not give you much in HP gins (10 HP max). Even that will be at higher RPM, typically on the last 1,500 before peak power.
Unless you have a mode where the engine requires more are like supercharging, porting, or cams. Then the stock system is restrictive and a higher flowing system is required to coop with the extra flow rewired.
For example, if you get a super charger and all stock intake you may get 50% increase in power. Ad CAI and you may get additional 5-10%, a god full exhaust (Headers + Cates + Cat back) will and another 5-15%, custom programming will maybe another 10-20%.
Don’t tack the numbers as actual I put them their for explanation purposes. It all depends on each component and how it is will complement the other systems.
and yes people share thier real workd experiences on this forum, we aren't here for the aftermarket companies we're here to help each other
I'm from Michigan and have buddys who are engineers both at GM and Ford.. All agree the CAI is a waist of money and a good way to ruin the pston rings in your engine. The CAI kits with the oiled filter have an added bonus (for the auto parts dealers) in that they can also ruin your MAS.
According to them, its not really the temp of the air that enters the engine that gives you more H.P. its the amount of the air. If the air temp were a factor then every car in winter states would see a performance gain on those cold frigid days we get up here. But this is not the case.
Colder air is denser and helps with heat soaking.
Any stock air intake with a clean filter can move just as much air as any CAI can. Another problem with the CAI (besides fouling the MAS), is that the filters do not meet the strict OEM requirements for cleaning dirt particles out of the airflow. So constant use of CAI will result in quicker wear of piston rings and intake valves.
A CAI will make your engine sound louder and give your exhaust a lower more "throatier" sound. This leads to the myth of a H.P. gain. The driver thinks the engine "sounds" more powerfull, so it must be.. But the truth is, its only louder. That is direct advice from two of the guys who design and test the trucks you love to drive and buy mods for. Save your money and skip the CAI. Get a tunner. It will produce real horsepower gain's by changing your engine and transmission programing. A performance exhaust will also provide a slight performance gain, but not much as most new vehicles are designed with low restriction exhaust systems now.
I may be a newbie to the forum and a newbie to Ford's (was always a Chevy truck owner) but I live in Michigan, in a GM town, was put through engineering school on my dad's GM salary and have several friends who are engineers for both Ford and GM. One of them works at Vistion village and designed parts of your (and my) truck... So I take them at there word when they say CAI is a waste of your money. If it were not, dont you think Ford would have put a CAI on a Mustang or one of the SVT vehicles by now..? In the winter, here in Michigan, when it is 20 degrees below zero, every car on the road has cold air induction. they dont get any performance gains.. And the line about a 'laminer air flow" is a gimmick also. Because once the airstream makes a 90 degree turn from your throttle boddy into your intake manifold the airflow becomes turbulent again. CAI is a gimick... Just like throtle body spacers that create a vortex in the airstream ( and cancel's out your laminer airflow from your CAI).. But enogh of my rant... Its your money, your truck, buy a CAI if you like...
So if colder air doesn't make more power by virtue of being denser, then I guess my intercooler on my racecar didn't add that power that it did. In fact, I guess that would mean any kind of cooling of the incoming air would be obsolete. So that means nitrous oxide doesn't really give you any power either since it's main purpose is to drastically drop intake tempratures. And, honestly, don't trust a dyno? I understand there are variables at hand, but if no one trusted a dyno then we'de just have one big pissing contest as to who's engine is more powerful with no way of knowing what kind of power they even make in the first place. I'm sorry, but any "engineer" you may know that tells you things like that should probably just go ahead and learn the basic physics and thermal dynamics of the modern internal cumbustion engine. Oh, and by the way, mustangs have been using CAI's from the factory in the form of a fender mounted intake tube. Even my 9th gen F-150 has a factory snorkel that comes from the airbox directly into the grill.
I can beieve those engineers told you that. They're the same guys that thought 4 threads would hold a sparkplug in a head, then let Honeywell sell them a plug design that breaks off in heads and put tunes intrucks that were so unresponsive it was dangerous to pass on a two lane. Gimmie a break! LOL
http://mustangforums.com/articles/20...rformance.html
Quote: "The new engine gets its cold intake air from a system built into the grille"
GT500 has a cold air intake factory from the KR version
Quote "Thanks to a cold air intake and other tweaks, power and torque are up 40 HP and 30 Lb-Ft, respectively" thats all factory
http://jalopnik.com/5199679/2010-she...00-first-drive
I'm real glad smart guys are designing our cars. If they didnt I wouldnt have a job as a mechanic.
