Need help with exhaust leak
Old Dec 4, 2009 | 03:57 PM
Outlaw1971's Avatar
I got JBA headers put on when my old exhaust mani's went and at the same time put on complete new system. It has been back to the shop 3 times now because of leaks. The latest is when Im accelerating I can hear a loud ticking/vacuum leak coming from the drivers side in the engine, I can hear it with the window closed and it is loud. However when the window is open it doesn't seem as apparent. Any ideas, could it be the flange? I shouldn't be able to hear any noise of ticking from the engine related to exhaust correct?
Old Dec 4, 2009 | 05:09 PM
avfrog's Avatar
What I would do is, start it when it is cold and feel around ALL of the connections. If there is a noticeable leak present, you should be able to feel it blowing out somewhere. You should also be able to see a black spot where it is leaking.
Old Dec 4, 2009 | 05:28 PM
Outlaw1971's Avatar
I shouldn't be able to hear that from inside the cab though hey?
Old Dec 4, 2009 | 06:09 PM
avfrog's Avatar
It's hard to say. I had two small leaks in a weld when I took out my cats and you could hear it sometimes if you listened for it. If the leak is fairly large you will defiantly be able to hear it inside.
Old Dec 4, 2009 | 06:48 PM
alex7191's Avatar
i have a leak and i can hear it in cab
