need to know how to clean a MAF
Old Nov 29, 2009 | 01:19 PM
BlackFord123's Avatar
hey guys I have 1998 ford f150 4.6L and I need to know how to clean the MAF can you guys give me any tips or directions for this?
thanks!
Old Nov 29, 2009 | 01:33 PM
avfrog's Avatar
Take it out and don't touch the elements. Spray some carb cleaner or MAF cleaner on it and let it dry. You should be set!
Old Nov 29, 2009 | 01:37 PM
Be sure to use electronic cleaner that does not leave a residue. there is a writeup for the 2004 up in the How To section. It shows the cleaner.
Old Nov 29, 2009 | 01:38 PM
f150fella08's Avatar
take the air box apart, get the safety torx or what ever its called,and take the sensor out and make sure you dont touch the wires, and spray about 3 or 4 inches away about 10 sprays or so,
i did mine with MAF cleaner, its in a gray can
no-mams's Avatar
make sure the maf is not hot, let the engine/maf cool down and then clean it.
Old Nov 29, 2009 | 08:34 PM
MudTerrain's Avatar
http://www.fordf150.net/howto/clean-...low-sensor.php
