Drop in K&N
Old May 6, 2009 | 10:49 PM
poolboy1191's Avatar
Exclamation Drop in K&N
Are they worth it?
I don't want to drop in a 50 dollar filter if it doesn't do much.
Does it thow any codes with it being oiled?
I know that 2001 Screw 5.4's have touchy MAF's. So I am alittle worried.
Old May 6, 2009 | 10:58 PM
Originally Posted by poolboy1191
Are they worth it?
First, if your paying $50, that is too much, unless it includes the recharge kit. Should be around $43. They will cause MAF problems if you over oil. They won't if you don't. You have to follow the directions when it say "lightly". I have 85,000 miles with one and never a problem.
Next, they do little or nothing for HP or MPG by themselves, but with the Gotts mod, I can see how they might be of benefit. The biggest savings is in replacement filters. I bought the filter, then the recharge kit 85,000 and over 4 years ago. Never bought another filter.
Old May 6, 2009 | 11:03 PM
radar's FX4's Avatar
bluejay, you know your stuff. i was thinking of getting 1 of these also,but i guess i'll hold off.
Old May 6, 2009 | 11:22 PM
Thanks! I've learned from my mistakes! I still think the K&N dropin is a good thing, since you save a lot on the cost of filters and my truck has shown no ill effects. It just does not give more power or gas savings.
There are some dry, washable filters to check out now.
Old May 7, 2009 | 06:40 PM
98Expedition10's Avatar
Love mine.
I have been putting them in various cars for the last 8 years. My Ford Exp. intake has been modified from the stock "Bong" fitting for reasons of air flow improvement. The current one has been installed since 2004.
There is a benefit in step response and HP, but the significance depends on your engine's Rev./Min. spent near or above 3,000 Rev./Min. I still recommend installing one if only because they are long lasting, and rugged.
In some earlier V-8's there is an IMT (Intake Manifold Tuning) system that intentionally limits intake manifold volume to help with with torque, and drive ability. This somewhat limits the benefit of the filter's low air restriction, but helps with "low-end" torque. However the improvement in response above 3,000 R/m. is very noticeable.
If you match the low restriction air filter with a free flowing exhaust system there is a direct benefit in engine response.
Old May 7, 2009 | 07:01 PM
Matts ford's Avatar
there are no real problems with K&N filters. its just that the oil can get onto the maf which can simply be cleaned. as long as you clean and oil it properly then it should be alright for a while. but if you notice any power losses or any running problems then i would clean the maf first. just a heads up.
and make sure you read the instructrions when you re-oil it. that way you dont over/under oil it.
edit: in all honesty if your looking for just a cleanable air filter then i'd get the amsoil filter. they are a dry filter and can be cleaned with a vacuum cleaner.
Old May 7, 2009 | 07:11 PM
fr8daddy's Avatar
$50 for the K&N, Check @ Walmart, I had bought mine there for $35.00..,
The Filter works ok, but a true CAI, will wake up the 5.4, and a good programmer will kick it in the A**.
Fr8daddy
2005 f150 SCAB, S&B cai, Banks ottomind programmer.
Old May 10, 2009 | 09:53 AM
Well a few months ago i had an AEM CAI on it. But my truck didn't like it. It kept throwing lean codes.
I have an Edge Evolution and it couldn't fix the problem.
End of story, i had to take off the CAI and havent had the problem since.
Does any one know of a good intake that hasn't thrown codes on their 97-03 f150?
Old May 10, 2009 | 10:28 PM
wreedKR's Avatar
what is the proper way to clean the maf on my 07 5.4?
Old May 10, 2009 | 10:38 PM
Buy MAF cleaner at your local auto store and spray it the opposite direction of the air flow.
You have to take the MAF out. Its kinda a b**** but it will help.
Old May 10, 2009 | 10:40 PM
Hespen537's Avatar
People I know spray electrical contact cleaner on them cause it leaves no residue. Will I try that? Prolly not.
Old May 11, 2009 | 02:10 PM
The MAF cleaner is like compressed CO2. It leaves no residue.
