Dissapointed in new exhaust setup
Old Apr 20, 2009 | 04:27 PM
01Screw17's Avatar
I had true duals with glasspacks, and stock cats. It used to run out at my bumper at 45 degree angles, and it sounded great, but after two years my tips began to rust and look like crap. So right after my glasspacks I dumped it under my bed before the rear axel. Exhaust shop guys said that it would be louder with this new setup, but boy were they wrong. It sounds terrible now, maybe a little louder than stock.
So my question is there anything I can do to make it louder, like maybe an X or H-pipe. I'm really dissapointed right now and can't stand the sound at the moment any help would be greatly appreciated.
Old Apr 20, 2009 | 04:53 PM
4.6 Punisher's Avatar
You're running true duals with no cross over pipe? Bet that's killing your low end.
Old Apr 20, 2009 | 05:02 PM
lordfeyr's Avatar
In my opinion dumping an exhaust is louder on stock height or lowered vehichles because the sound can echo and bounce around under the truck. When you lift the truck like you did it doesnt really do anything. Depending on the tips you had they were resonating the sound and with a small inlet and large outet they work like megaphones to project the sound. (Think of those things cheerleaders use to make people hear them)
Old Apr 20, 2009 | 05:06 PM
bigdog87's Avatar
I live with it daily.
Old Apr 20, 2009 | 05:10 PM
It's ok buddy, we all know you've learned better now, lol.
But back to the topic, an X is in order for some of you torque back, even though you haven't mentioned it. As for the sound, you could run a Lightning exit. That will get your sound back and then some depending on what size tips you run.
Old Apr 20, 2009 | 05:13 PM
bigdog87's Avatar
I'm about ready to beat some *** at the only good exhaust place here, they don't want to put one in for me, probably because there isn't enough money in it to even bother. So I'm redoing my tailpipes sometime and I'll make them throw one in there then.
Old Apr 20, 2009 | 05:21 PM
No one want to make money at an exhaust shop?! You could always do it yourself, just find a welder and a hacksaw!
Old Apr 20, 2009 | 05:22 PM
bigdog87's Avatar
I guess 50 bucks isn't worth it to them?
Old Apr 20, 2009 | 05:28 PM
01Screw17's Avatar
So you guys think if I just added some bigger tips, it would make it louder. Because I just welded some 2.25 turndowns to it right now.
Old Apr 20, 2009 | 05:31 PM
01Screw17's Avatar
Yeah with my old setup, the one I should not have thrown in the dumpster, I was running 24 x 3.5 inch tips.
bigdog87's Avatar
Probably, it'd give it more to echo off of.
Old Apr 20, 2009 | 05:38 PM
Oh yeah, definitely. You know when you roll up a newspaper in the shape of a cone and talk through it, it sounds like you are louder. Same principle applies to tips. Just get a good set of 3.5 X 12's and run them out the side.
Old Apr 20, 2009 | 05:46 PM
01Screw17's Avatar
yeah, your definetly right, I need some tips. Should I also thrown on an H or X pipe as well? Or will the tips alone get my sound back.
Old Apr 20, 2009 | 05:55 PM
The tips alone will get your sound back, but the H/X will alter your tone and add some power back. H's are cheap and still have that nice choppy raspy true dual sound, but so do X's, but more moderately.
Old Apr 20, 2009 | 06:04 PM
bigdog87's Avatar
Couldn't of been said any better. I prefer X's because they are more based on performance than H is based on sound.
