Dual Exhaust Question
as long as you dont plan on having the pipes exit BEFORE the rear wheels on EACH side you will be fine..
the pipes will run straight all the way over the rear axle then bend right before the spare tire. so you should good.
as far as the price... that sounds a little pricey, and are you going to be running quad exhaust? you shouldnt need two si/do mufflers... just one.. unless your going for true duel. then you will need 2 si/so mufflers....
welcome to the site!!
-LTZ
-LTZ
