What intake should I get?
Old Oct 27, 2008 | 10:17 PM
knighj1's Avatar
You need to use the search feature!!!!
Old Oct 27, 2008 | 10:23 PM
willys5555's Avatar
ok....i can never get the specific answer i want that way....sorry though
Old Oct 27, 2008 | 10:37 PM
coobies5's Avatar
yeah man, you get a cai, you want the air to be cool right? hahaha, so wrap the pipe and thus you'll keep the cold air from outside the engine compartment cool. leaving it unwrapped, it'll just keep the pipe pretty warm and then the air inside it will be pretty warm.
Old Oct 27, 2008 | 11:08 PM
willys5555's Avatar
i guess that makes a lot of sense...do the plastic ones keep the air any cooler? or would i have to wrap those also?
Old Oct 28, 2008 | 12:59 PM
knighj1's Avatar
wrap it/ leave it not going to make much difference, also the spacer is a better paper weight than a performance add on
Old Oct 28, 2008 | 01:23 PM
ModBargains's Avatar
A plastic tube simply does not absorb as much heat as a metal tube does.
Old Oct 28, 2008 | 01:57 PM
97f150xl11's Avatar
Screw the COI and exhaust crap. The 97 4.6 does not breathe worth a **** internally. You need to get the inner air port working better before a COI will do much. It would be the same price for you to put on used P.I. heads from a newer 4.6 which should get you about 45 more hp conservatively. you will get no where near that out of COI and exhaust. Of course the heads are a bit of a project. And don't forget that if you put PI heads on a non PI motor it will bump compression to about 10 to 1. For me...(living in the mountains at high elevation), higher compression is a good thing because the thin air lowers it.
Old Oct 30, 2008 | 09:35 AM
MikeSwt's Avatar
Originally Posted by coobies5
if you get a cai, and the chrome tubing, and you're going to leave it exposed, its not going to do all that much for you since the pipe is going to be hot from the engine, you need to wrap it in some sort of heat shield if you want any performance out of it.
The main reason I ran the S&B
Old Oct 31, 2008 | 11:26 PM
jblanchard591's Avatar
Any suggestions on where to find a cold air intake system for a 99 Navi with the 32 valve 5.4L? I have the oval throttle body and no one makes an oval kit yet. I've checked with K&N, AEM, AF1, etc... Help!
Old Nov 1, 2008 | 05:09 PM
Veteran: Army
https://www.f150online.com/forums/ex...take-pics.html
I know K&N makes one for your truck try for the '03 Navigator and that will broaden your options
Old Nov 1, 2008 | 05:24 PM
hoss66's Avatar
the heat of the intake tube is not going to make any difference, the air is moving through at such a fast rate that it would not have enough time to get hot just from that.
Old Nov 1, 2008 | 05:30 PM
Veteran: Army
that's why the AF1 and the stock intake have the lowest intake temp charges compared to the other intakes according to Mike Troyer and his research...
