LT Guys
Old Jun 20, 2008 | 01:45 PM
jbrew's Avatar
LT Guys
Why haven't I heard of this ? I just had ANOTHER O2 code -B1S1. The O2's are almost new. This is prolly the forth time in the last 3 months. I checked all the wires / harness many times on both foward sensors. I had some exhaust/EGR leaks . So I completely did the exhaust again/ welded in new O2 bungs for the back because they leaked - Anyway it's solid as _ _ _ _ !
I even tried swapping forwards and I still got a B1S1 fault!! WTF!
Well, I ripped the freakin heat shield off this time and there it was. The AC drain is directly over the O2. With LT's you have to reposition the O2's in the Collector or Cat depending on the system. Mine happen to be in the collector which is right under the AC drain. I didn't notice that when doing the LT install last fall and I haven't run my AC until recently.
So if you have this problem - check the position of that drain tube. I extended the tube out of harms way. Couldn't even see the damn thing with the heat shields on.
Old Jun 20, 2008 | 04:53 PM
shifty_85's Avatar
or just dont use ur A/C and roll down your windows...save some gas Jbrew
Old Jun 20, 2008 | 09:47 PM
jbrew's Avatar
LOL , You know - I've been waiting for the AC to take a dump .
Since 2003 - It's a freakin Timex.
Old Jun 20, 2008 | 09:52 PM
shifty_85's Avatar
my A/C hasnt had anything done to it ever since 97 when it was made and it still blows cold...very cold. i dont use it that much thoe.
Old Jun 21, 2008 | 12:29 AM
Klitch's Avatar
brew, ty for the heads up. have u considered "tweaking" the drain? i dont use my AC unless the lil ones in the truck with me. poor kid dont need to sweat like that in a car seat
Old Jun 21, 2008 | 01:10 AM
minimonster17's Avatar
hmm... i didn't have this problem, however, i moved my o2 bungs when i did my install. i look again just to be sure i won't run into a problem like you did.
Old Jun 21, 2008 | 03:04 AM
jbrew's Avatar
Yea I re-routed it - actually just extended the hose. The b^tch of it was - The AC will drain a little after shut down , but when I'm not moving it dribbles from a different spot - I thought the drain was closer to the firewall.
When I'm moving it hits the O2 Sensor but dissipates pretty quick - right after causing the sensor to bugf^cky - The only way I confirmed is that I noticed the top of the heat shield trapped a little drainage /saturation and the sensor itself was, clean. A little moister in the harness as well.
Well , I'm not if all models have the drain pipe there - But Ford did put out a TSB on it - Included a modification, I have the illustations in gallery 3.
