Airaid MIT Tube Worth it??
Does anyone have this tube on there 5.4L 3V?
I have an AFE drop in and don't want a full blown CAI, but was looking at this tube for a little extra ooomph.
Just curious if anyone has it and likes it...
http://www.shopatron.com/product/par...360.2096.0.0.0
1st:cut the bladders off, clean, with the pipe, then clean all the burs off
2nd:take a thin ply-able plastic binder "like from a code book"cut pieces to cover the holes ,use black duct tape to fasten it. then take heat resistant
tape wrap the hole tube followed buy black duct tape.
3rd:yank the tube out of the fender wall, then purchase either a 3"pvc clean out tee or coupling place it to the the intake tube then the other end 3" PVC out the fender wall ,wrap the end in foam tape for cushioning,then paint it black.
the option with the cleanout tee is for a ram air tube that u run 3" drain tile screw it in the clean-out tee part, run it down to the tow hook,fasten it with big black zip tie's. even with the material you have to buy it's still cheaper than that ariad tube, i had all the material sitting in my garage an was board one day an this is what i came up with.
I've had since the truck was almost new. It works well and certanly cleans up things under the hood.
If your time is worth anything to you just by it and put it on instead of cobbing some POS out of duct tape.
I had it on my 2006 F150 before I put the S&B full intake on. I felt a power increase and an increase in mileage. It's not as much as a full intake.
