Exhaust Help!
Exhaust Help!
Alright so i'm looking for some more rumble and tone out of my exhaust. I currently have a flow master super 40 series welded in place of stock muffler with a 3" pipe running back behind my rear right wheel... That's it...
It sounds ok....
But i want something MEAN and like a pissed off truck sound...
What do you guys suggest... Any explanations will be appreciated!
It sounds ok....
But i want something MEAN and like a pissed off truck sound...What do you guys suggest... Any explanations will be appreciated!
Check out my setup in the vids below, but it depends on what you want. If you just want a little more rumble, I would add a 4" tip, I changed my 3.5" to 4" when I had a si/do 40 series and it was like night and day(also changed it from straight out back to 45's out the corners) but I got tired of sounding like every other f-150 out there so thats what I ended up with.
I don't want any tips on the end and the pipe is just bent and ends right behind the right rear wheel... Not a tip guy, just like the pipe all by itself
So i'm looking for New muffler/mufflers? No cats, cats, x/y pipe??
I don't know..
I want more sound but i do not want it obnoxious and i don't want to drastically impact hp/torque
I don't know..
True duals, magnaflow high flow cats, x-pipe, and then the muffler or no muffler of your choice, but the tip will make it LOUDER and DEEPER, so the whole pipe thing is up to you, and ditch the 3" pipe, 2.5" is more than enough.
i cut the muffler and cats off mine and it sounds good... its not extremely loud but it gets ppl attention... heres a clip of my exhaust... its not dumped in the vid but im fixin to do that
http://youtube.com/watch?v=fDWxqLHZ_GU
if that dont work try this one (if u have a myspace profile)
http://myspacetv.com/index.cfm?fusea...ideoid=2958975
http://myspacetv.com/index.cfm?fusea...ideoid=4657395
