questions about cat back
Old Feb 15, 2008 | 05:00 PM
KDracing's Avatar
i am thinking of doing a cat back exhaust, and want something kinda loud (almost enough to wake neighbors up but not get cops called ) i was thinking of doing duals out the back, with a dynamax bullet for the muffler. only questions are where can i buy piping to run out the back, how big (was thinking 3" to 4" tips) and how loud are the bullets??????
Old Feb 15, 2008 | 05:21 PM
esf's Avatar
esf
Well if that's the direction you want to go then you're going o have to cut the stock Y pipe and run an x pipe and have the pipe custom bent to however you want it to exit or dump. Just buy the mufflers off of Summit Racing or somewhere similar. Have a shop do the piping and you can purchase the pipe from them. You may lose some bottom end with that setup. Derrick929 ran true duals 2.5" pipe with long tube headers and high flow cats and said it killed his bottom end. He went to a single 3" cat back and said he likes it a lot better. Just something to think about. If set on the true duals then maybe just run some 2.25 inch pipe.
Old Feb 15, 2008 | 06:33 PM
KDracing's Avatar
don't know if i want that then, i need truck for towing, i also wanted to do it myself to cut down on cost. thanks for info
Old Feb 15, 2008 | 09:03 PM
esf's Avatar
esf
http://www.troyerperformance.com/cgi...atalogno=15609
