Intake VS. Headers???
Old Jan 19, 2008 | 08:13 PM
thumper2001's Avatar
Ok well i tried posting in general discussion but didnt get any reply so I will try here. I am planning on buying a Volant cold air intake with a Mass airflow sensor and throttle body from Jet. Or some OBX headers with the long tubes and without the cats but in order to do that I am going to have to get a x3 custom tune from Troyer also so the truck will run right. So my question is which setup should I get first because I cant afford it all at once? I know that a engine is a pump and to get more out of it you have to let it breath, "in and out", I already have strait pipes out the side so I am thinking I should lean towards the intake setup first. Tell me what you would do.
Old Jan 19, 2008 | 08:26 PM
built54's Avatar
get the custom tune with the intake and maf first....
Old Jan 19, 2008 | 08:29 PM
I cant get the tune first because I am going to have them turn the o2 sensors of and have it set for the exhaust and intake and all.
Old Jan 19, 2008 | 08:30 PM
built54's Avatar
you cant get the maf without a tune unless you want to blow ur engine...
Old Jan 19, 2008 | 08:38 PM
Why do you base that statement on? Nothing in the sites advertising them say you have to get a tune. Jet even says its compatible with cold air intakes and/or stock.
Old Jan 19, 2008 | 11:16 PM
TexEdition's Avatar
Dude, you'd be well advised to listen to what built54 has to say before any "advertisements".
Yeah, I know, advertisements never lie... neverthe****ingless..
Listen when built talks..
Old Jan 19, 2008 | 11:20 PM
ScottFF00's Avatar
Headers and exhaust first.
Old Jan 19, 2008 | 11:26 PM
I didnt say advertisements never lie but I would like to see what he has to support what he is saying. If i listen to him blindly wouldnt I be doing the same thing as listening to advertisements blindly? Come on man.
Old Jan 19, 2008 | 11:33 PM
TexEdition's Avatar
Understood..
And I'm pretty sure that he'll post more info about why he said what he did than most of us can understand.
That guy is one of the best resources on this site for anything to do with F150's.
That's all I meant, that if built says you should tune and upgrade the MAF first then that's probably the way to go.
No offense, I'd just not trust anything in any advertisement.
Old Jan 19, 2008 | 11:36 PM
Understood..
Old Jan 20, 2008 | 01:39 AM
4.2trimble's Avatar
my vote goes for headers and custom tunes!
Old Jan 20, 2008 | 09:57 AM
openclasspro#11's Avatar
longtubes and tunes!
Old Jan 20, 2008 | 12:14 PM
Thanks guys, anyone else got an opinion? Its starting to look like the exhaust first.
Old Jan 20, 2008 | 12:33 PM
Veteran: Army
built54 has done just about every mod to his truck, the reason he said you need a tune with the MAF because it will make your truck run lean = blown engine (and not the good blown either)
i too vote for the exhaust first, when you get your intake and MAF and your troyer tunes upgrade to #24 injectors all at once to make your effort worthwhile
Old Jan 20, 2008 | 12:39 PM
Ok, finally I get an explanation, Thank you and I agree with your what you said, I think that is the way I will be going. Anyone else have an opinion?
