Cherry Bombs
Old Jan 12, 2008 | 04:11 PM
Duffman0286's Avatar
Cherry Bombs
trying for that gut rattling sound with use of a 2 high flow cat rather than 4 wanting true dual set up on short headers to one maggy high flow cat and o2 sensors in front and behind that cat to a cherry bomb (2.5 tubing all around by the way) that exits in front of rear tires
what length of cherry bomb or smitty glass pak or other brand give best tone and is loud as hell?
Old Jan 12, 2008 | 06:44 PM
hockeyfanjeff's Avatar
i would go with cherry bomb extreme muffler instead of the glass pack. 6" long case single chamber, its loud and deep and a great tone, not as raspy as some glass packs can be
Old Jan 12, 2008 | 10:44 PM
glasco's Avatar
i have a single glass pack and 4" tip and it sounds good but iam thinking of putting a X pipe and running two glass packs and 4" tip
Old Jan 13, 2008 | 12:33 PM
anfo's Avatar
I like the magnaflow magnapacks (stainless glasspack), I have them on my mustang and they are nice and throaty and just get deeper with age.
Old Jan 13, 2008 | 06:13 PM
this is really sounds good to me now should run 2 mufflers like i want or one? for more sound
Old Jan 13, 2008 | 07:35 PM
i got mine pretty cheap $44 shipped from www.performancepeddler.com and did their best offer option. They come in si/so and si/do but since they're so cheap i'd go for two si/so to come after the cats. you can put in an x-pipe or h-pipe between the cats and mufflers if you want also. here's a clip from the cherry bomb website of an 05 4.6L http://www.cherrybomb.com/manager/pr...d_F150_4-6.mp3 doesn't say what mufflers are on it but my guess is either pro or extreme
http://cherrybomb.com/sound-pad.html here you can here a mustang GT with the extreme
Old Jan 14, 2008 | 09:26 AM
kaboom10's Avatar
The less cylinders a muffler has to work with the louder it is. Ever hear a quiet Harley? So if you have 2 mufflers instead of 4 the noise level goes up.
Old Jan 15, 2008 | 08:08 AM
Green_98's Avatar
the above statement is very true. I had a Y pipe with dual tailpipes a while before I put on true dual 2.0" (no mufflers on either setup) and the true duals are a he// of a lot louder.
If you want the earth-shattering loud sound, go hi-flo's and true duals with no mufflers...i doubt you'll be able to stand it it will be so loud.
Check out some exhaust clips on YouTube, they've got a bunch
Old Jan 15, 2008 | 08:40 PM
well that settles it that sound clip is sweet... true dual 2 cats and cherry bomb extreme's got my vote!!! thanks every body
Old Jan 16, 2008 | 11:05 PM
BLACK05STXJT's Avatar
If all you want is loud, then i say the cherry bomb extremes, just be prepared for a server drone at 70mph. i have the same setup you are getting and im about to have them run out the back cause the drone on long trips is not worth the noise. hope this helps jared
Old Jan 16, 2008 | 11:08 PM
attworth's Avatar
I've got true duals with some no-name glass packs on mine. It sounds ok for a 4.2. I'm not real happy with the look of it, but I don't crawl under the truck very often so it's no biggie.
I'll be swapping them from some real mufflers soon.
Old Jan 18, 2008 | 07:49 PM
corey v's Avatar
i have a cherry bomb extreme on my 4.6 with turn downs and it was so loud in the the cab but it has a reall good sound to it sounds almost like a mustang, but i went the other day and had them do my exhuast like on the harley f150's sounds even better
Old Jan 22, 2008 | 01:21 AM
well i am a fan of cabin drone and if that start to bother me i just crank the country music haha
