advice for more noisein my 06 f150
Old Jan 7, 2008 | 08:33 PM
monsterstxn06's Avatar
i have a 2006 f150 and i currenty have flowmaster 40 series on my truck out the sde in front of the tire, i like my tips ad where they are located but i want more sound i was wondering what i could do. change my muffler? get an aftermarket cat? remove the cat all together? any advice? im working with about 400 dollars... i have a 4.6L by the way
Old Jan 8, 2008 | 01:48 AM
hoss66's Avatar
run true duals with no mufflers and an x pipe. this should sound pretty good. if you have enough money then get the high flow cats they woud also help.
Old Jan 8, 2008 | 02:20 AM
Get a magnaflow muffler.
Old Jan 8, 2008 | 02:26 AM
hoss66's Avatar
magnaflow is a great muffler but would never come close to the sound of a 40 flowmaster much less be louder. stealth what about you off road roush how does it compare to the flowmaster?
Old Jan 8, 2008 | 02:38 PM
thanks for the advice hoss and stealth, my buddy has the same truck as me and he runs magnaflows and mine is a lot louder, but his still sounds nice, hoss do you run x pipes? and will they hurt any performance? i have only heard of x pipes going on mustangs before never on a truck
Old Jan 8, 2008 | 02:50 PM
ScottFF00's Avatar
Since you are in Florida. Remove the cats. Try it before you spend anymore money, you might actually like it.
Old Jan 8, 2008 | 02:57 PM
iwas told i couldnt remove my cats becuase there is an o2 sensor on it and my truck wouldnt run without it, i dont know if this is true or not. but removing my cats was my first thought
Old Jan 8, 2008 | 04:35 PM
hoss66's Avatar
if your truck has 4 cats you can remove the back 2 but if it only has 2 i would not do that. if i had the money i would have an x pipe and it should actually improve your performance. see if you can get built54 to chime in he has had over 20 exhaust systems and i know he runs one so he should be able to give some actual #'s
Old Jan 8, 2008 | 09:01 PM
yea im goign to have to find out exactly how many cats i have, but ive herd an x pipe before on mustangs and i like that deep throaty sound i think x pipes may be the way to go have any idea what that would run me installed?
Old Jan 9, 2008 | 02:01 AM
hoss66's Avatar
i just checked summit and you can get a dynomax universal x pipe for $44.39 part # 88327. i would think you should be able to buy that and have it all installed for under 400.
Old Jan 9, 2008 | 02:28 AM
mSaLL150's Avatar
x-pipe will actually reduce sound on the f150, but can improve performance with the right tune.
what i would do is replace your factory cats with high-flows, or install pacesetter longtube headers. either one will add a ton of sound, headers adding major performance.
Old Jan 9, 2008 | 03:28 AM
azmidget91's Avatar
you have 2 only the 04's had 4
o and just run no muffler
Old Jan 10, 2008 | 07:34 PM
how would my truck run with no cats? could i do it on my 06 if it only has 2 cats? what about the o2 sensor? maybe i will just cut off my muffler and see how it sounds and go from there
Old Jan 12, 2008 | 03:50 AM
hoss66's Avatar
you can run it with no cats but you would have to buy o2 simulators and its not worth it. i am actually running no muffler now and it sounds good especially for the 13 dollars it cost me. i added about 3' of pipe to get it out from under the cab and then just put on a turndown.
Old Jan 15, 2008 | 12:08 AM
ScottFF00's Avatar
Your truck will run with out any of the cats. But it will throw a CEL. Just get a tune and have them turn off the rear off sensors when you do so. Justin @ VMPtuning.com is just down the road in Debary and he'd be willing to hook you up with a tune and shut off the rear 02's
