Another intake question
Originally Posted by Kabby
So i've read alot of the threads about the different intakes but I can't desice between the volant intake or AF1.
negative! They first must prove that the intake was the cause of the damage, now if you sling a rod or something then yeah they will blame it on the intake. If you go get your oil changed or something under warranty, by law they can not void because the intake.
Originally Posted by ParkM
negative! Ford will not and can not void your warranty! They first must prove that the intake was the cause of the damage, now if you sling a rod or something then yeah they will blame it on the intake. If you go get your oil changed or something under warranty, by law they can not void because the intake.
