Magnaflow vs. Spintech
Old Nov 26, 2007 | 04:48 AM
ParkM's Avatar
I currently have a #16616 lightning style SI/DO cat-back on my 4.6L. I'm wanting to replace the factory Y with a X-pipe into dual SI/SO Spintech Pro Streets dumped, keeping the pipe size at 2 1/4" to reduce the loss of my low end power.
I'm just wanting a little more sound and the added performance of the X-pipe.
Will I see any performance gains or will all my low rpm power move into the higher rpms?
Old Nov 26, 2007 | 08:27 AM
built54's Avatar
stay with the magnaflow and get an x pipe and get a DIDO muffler or it will do nothing to get an x pipe if you go back to a single inlet muffler
Old Nov 26, 2007 | 12:27 PM
ParkM's Avatar
so a Di/DO is better than 2 separate SI/SO's? I would think that 2 11" SI/SO Maggies would sound better than a DI/DO 14" or 18"?
Old Nov 26, 2007 | 01:20 PM
mSaLL150's Avatar
they makes an 11" DI/DO...
Old Nov 26, 2007 | 01:43 PM
ParkM's Avatar
That's a negative on that 11" DI/DO Maggie. It has the X-pipe built in and I don't want that. I want the standalone X and then two SI/SO 11"s, that way I can get the X closest to the cats as possible and still keep the mufflers not right under the cab minimizing the drone.
Old Nov 26, 2007 | 02:20 PM
mSaLL150's Avatar
if your worried about minimizing drone then why would you want 11" mufflers in the first place? smaller muffler = more drone/sound. maybe get 14" or 18" mufflers for better sound reduction...
Old Nov 26, 2007 | 05:39 PM
ParkM's Avatar
I have a 18" SI/DO right now and I just want more. At the same time though, I do have passengers sometimes and it's nice to comfortably carry on a conversation or not have to have the radio at crazy levels.
Old Nov 26, 2007 | 05:49 PM
openclasspro#11's Avatar
zero droan out of my setup- 2-2.25" siso 4x9 magnaflows-x-as close to original y-pipe as possible-phil
Old Nov 26, 2007 | 06:38 PM
built54's Avatar
I have a 11" dido magnaflow, no internal X.
