looking to get magnaflow high flow cats
Old Nov 19, 2007 | 08:07 PM
4wd150's Avatar
hey, i am looking to possibly get high flow cats like maganflow is good i hear. how many do i need? whats the best place to go through to buy them? its for a 2000 f150 5.4l
can someone give me some advice on this
thanks!
Old Nov 19, 2007 | 08:25 PM
_cashel's Avatar
You only need two. The two places I know of are Troyer and Ebay
Old Nov 19, 2007 | 08:29 PM
4wd150's Avatar
and that should pass emissions for inspection?
how do i figure what size i would need?
thanks for the help man
Old Nov 21, 2007 | 07:08 PM
Mo Power's Avatar
4W,
I will be putting on some high flow cats within the next two weeks. I'll let you know if my CEL shows up. Magnaflow claims replacing the four stock cats with two of their high flows will not trip the CEL. We will soon see.......
Here's the Troyer site with the different model numbers (I bought 94306):
http://www.troyerperformance.com/cgi...c%20Converters
Later
Old Nov 21, 2007 | 07:17 PM
_cashel's Avatar
standard piping size should be 2.5", and you shouldn't fail inspection with it.
Old Nov 21, 2007 | 08:16 PM
built54's Avatar
my truck burned cleaner and sounded much better with these, great investment!
Old Nov 21, 2007 | 08:20 PM
jbrew's Avatar
Same here - No light..
Old Nov 21, 2007 | 08:41 PM
4wd150's Avatar
thanks guys
Old Nov 21, 2007 | 08:48 PM
shifty_85's Avatar
no cats/ o2 sims. No light smells good to!
Old Nov 21, 2007 | 11:32 PM
Jughed's Avatar
Do you have to build a new Y pipe? seems like the second stock cat has the bend in it. Got any pics of of your Y pipe Brew. I got back In town last night, Im gunna get you those pics for you this weekend, finally got cold enough to hide in the garage without the wife nagging me about doing crap to the yard.
Old Nov 21, 2007 | 11:49 PM
jbrew's Avatar
My cat's are after the Y before the muffler - they won't fit between long tubes and the Y unless you have a welder and a 3" ID cat flange.
To anyone ordering Pace Setter Long tubes - make sure you order the 3" cats - because it's very tight in between..
Old Nov 21, 2007 | 11:58 PM
Jughed's Avatar
forgot you had long tubes. I can weld exhaust, just wanted to check out one that is already done. If I have to weld new bends in Im just going to build a new Y pipe I think.
Old Nov 22, 2007 | 12:07 AM
jbrew's Avatar
Pace Setter charges $125 for the 3" off road pipe you can get included with their headers - I didn't have a welder - I returned the 3 " off road pipe and used stock. Plus their off road pipe doesn't include O2 ports which pi$$ed me off because their picture of the kit SHOWED an O2 ported Y-Pipe. It was total false advertising on there part!!!! Carfull with Pace Setter - they are a$$holes to deal with..
Old Nov 22, 2007 | 04:31 AM
shifty_85's Avatar
why do you need cats? i got a down pipe that got rid of them running true duels with mufflers. im just wonderin why you would need cats at all.
Old Nov 22, 2007 | 07:19 AM
Jughed's Avatar
I would run no cats, just worried about catching a code. How long you been running felineless shifty?
