Magnaflow or Flowmaster?
Originally Posted by BOWDOGG
Ok, just got home from work.
Does the Magnaflow 40 have a low bass sound or is it crackle. I want a system that will give the lower bass sound. Sure, I understand that it matters about performance first, but like it was discussed, mufflers don't really do that. I want a good sounding system, then go from there with performance.
The Magnaflow "magnapack" mufflers will give you that deep bass sound at idle and low RPM, as well as dynomax bullets. The flowmaster will be deep at idle but will also scream at the higher RPMs a little more, where the magnaflow cuts out a little in the upper RPMs.
Im basing this off of two trucks. a buddy has a 5.4L F150 with a 14" maggie, and i have a 14" flowmaster on my 5.4L.
only one i would consider is the 4" round casing magnaflow, its 14" long and looks round. it is called "magnapack" muffler. the rest of them just aren't loud enough.
After doing my research I chose the magnaflow because the power increase is a little greater than the flowmaster. The flowmaster mufflers are louder because the exhaust has to travel through different chambers. My magnaflow muffler has a flow through design ( which = more power ). The magnaflow mufflers aren't as loud as flows but they perform a little better. I have my exhaust dumped right after the muffler and it sounds incredible. Remember the smaller the muffler the louder it tends to be. Hope this helps.
because they are pretty much the best muffler around. they sound amazing and actually improve performance. flowmasters do pretty much the opposite. as for the roush, ive heard some good things, but not like what ive heard about magnaflow. why do you call mike t and ask him what muffler is best. guarantee he will say magnaflow
www.hottexhaust.com
has some fairly decent prices. if i was you, id also get a cut out. that way when you want it loud you can just take the cap off
