Aftermarket Throttle Body?
Old Nov 5, 2007 | 11:41 PM
zhoova928's Avatar
anyone have a pic of an aftermarket throttle body on with an aftermarket air intake??
curious if the two will work together...
also anyone who has one what gains did you get? was it worth it?
thanks
Old Nov 6, 2007 | 11:09 AM
mjd5.4's Avatar
Thumbs up
yes to both questions.
I put a bbk 75 mm on my truck, it gained a little more than a tenth in the quater at the track and one mph!
Old Nov 6, 2007 | 04:24 PM
zhoova928's Avatar
do you have a pic?? did you install yourself? if so what are the steps?
thanks
Old Nov 6, 2007 | 05:10 PM
Wang13256's Avatar
i have a bbk 75mm on my 4.6 along with the AF1.. i love it.. what u would have to do is disconnect your intake from your throttle body... then unclip the throttle positon sensor wiring, disconnect your throttle cable, spring and cruise control cable from the throttle body and then you are free to unbolt the throttle body itself.. this is where the problem comes in.. i believe you will need torx bit to unscrew the throttle position sensor from the throttle body to put on the new one which is what gave me a problem.. i stripped mine so i left it on the factory and bought a new one for my bbk.. it was $47.00 and i put regular 5mm bolts through instead.. then your ready to install your new TB.. make sure you have a new gasket and line it up (a little pain the the a$$ for me) then bolt it in, replace your spring, cruise control cable, throttle cable and re clip the TPS... connect your intake and you good to go..
Old Nov 7, 2007 | 09:58 AM
mjd5.4's Avatar
Talking
I can try to post a picture, make sure you take off elbow and blend in the throttle body to elbow, mark it with gasket that comes with tb, it will whistle if you don't, I drove my truck for two weeks before I rimmed out the tb to elbow. drove me crazey!!!!!!!!
It is worth it if you have the 5.4!
Old Nov 7, 2007 | 10:04 AM
MGDfan's Avatar
The stock TB is large enough - you will gain little on a lightly modded/stock truck, except a lighter wallet and perhaps bragging rights / bling. Spend your perf dollars elsewhere.
Gains: https://www.f150online.com/forums/sh...1&postcount=11
And, if you still want to do this, some prep:
https://www.f150online.com/forums/sh...=throttle+body
MGD
Old Nov 7, 2007 | 11:26 AM
Wang13256's Avatar
damn.. thats why i have that wistle.. i thought i had a leak or somethin but havent had the time to check it out.. thanks for the info... lol.. so the best way to do this is with a dremel??? alrighty then.. thanks. TIM
Old Nov 8, 2007 | 08:12 AM
mjd5.4's Avatar
Thumbs up
The $200 tb was a cheap up grade for me.
I ran truck at track before and after the tb and truck picked up a solid tenth+
and one mph for me.
No (Pinks) for us at no problem raceway! Canceled!!!!!!!!
