Exhaust getting put on tomorrow!
Old Nov 5, 2007 | 10:10 PM
JohnWade150's Avatar
Smile Exhaust getting put on tomorrow!
well if the guy can fit me in tomorrow after school i am getting dual straight pipes all the way back then turned to the side... How big should the pipe be that is getting ran back? I have heard 2 1/2 so should i go with that? And he said i could choose the tips i wanted when i got down there.
Ill have pictures up once i get it on too
Old Nov 5, 2007 | 10:14 PM
07fx4silver's Avatar
2 1/2 inch piping should be perfect
Old Nov 5, 2007 | 10:24 PM
ok then 2 1/5 it is... but is there a sound difference if you go bigger/smaller?
Old Nov 5, 2007 | 10:34 PM
Not really 3 inch might be slightly deeper but you'll lose too much back pressure in return and the audible difference is very small. Stick with the 2 1/2 and go with some 4 inch tips
Old Nov 5, 2007 | 10:36 PM
thanks bro ill get pics when i am done
Old Nov 5, 2007 | 10:54 PM
Green_98's Avatar
2.5 is plenty big enough.
i lost some low end tq on my 98 4.6 when i had true dual 2.0" pipes put on (no mufflers)
get ready, it's loud
Old Nov 5, 2007 | 11:00 PM
yea i want it loud my friend has it 2 1/2 and 5inch tips i think and i like the way his sounds so i decided to go with that and it was cheaper than putting glass packs on
Old Nov 6, 2007 | 07:24 AM
MGDfan's Avatar
Preserve your exhaust gas velocity, and hence your low-end torque - go 2 1/4" max, and ensure they are mandrel-bent. If not, find another shop.
Old Nov 6, 2007 | 08:23 AM
openclasspro#11's Avatar
especially if its a 4.6- go 2.25"-phil
Old Nov 7, 2007 | 04:57 PM
got them put on.... there pretty sweet there loud when you want them to be quite when you want them to be
ill get pic when i get the camara back
Old Nov 7, 2007 | 05:39 PM
4wd150's Avatar
sorry to "jack" your thread, but i have a quick q because i am getting my exhaust put on this week too. what exactly is mandrel bent? im a noob when it comes to this stuff. do i just ask the shop if they mendrel bend or something?
thanks
Old Nov 7, 2007 | 05:52 PM
06F150STX's Avatar
mendrel bend is a smooth bend, not creases in it. its the only way to have it.
Old Nov 7, 2007 | 07:44 PM
rtodd's Avatar
i just got 2.5 inch put on mine , sounds great brought them out the back.
my son had his brought out at the rear corners and it's louder 2.25", he has a short bed regular cab mine is a supercrew.
unless you building a racer, mandrel bent is just an extra expense
Old Nov 7, 2007 | 08:04 PM
MGDfan's Avatar
The corrollary statement here would be: unless you are building a chitbox and don't care about performance, mandrel-bent is well worth it, lol.
Originally Posted by Exhaust_Guru
"THE EXHAUST PIPE
To save costs, your typical stock exhaust uses small diameter, crush bent pipe. Crush bends are easy to make in mass production. However, crush bends can reduce the flow of a pipe by up to 50 percent. Your typical exhaust system made by the local neighborhood muffler shop is also crush bent. The best exhaust systems, like most pre-made exhaust systems, come with mandrel bends.
Mandrel bending is done by a special machine that uses a non-crushable insert, or mandrel, that goes into the pipe while bending to prevent it from being crushed. If you are making your own exhaust, you can buy pre-made mandrel bends from MagnaFlow, Burns Stainless, Kinsler or Bassini. The huge speed parts mail order emporium Summit Racing stocks both the right kinds of mufflers and mandrel bends.
It is better to use a smaller diameter mandrel bent pipe than a larger crush bent pipe. Remember that maintaining velocity is just as important as reducing backpressure."
Old Nov 7, 2007 | 08:21 PM
or a leafblower aka straight pipes from 04 forum
