Boxed or Open
Old Oct 21, 2007 | 07:46 PM
troy eck's Avatar
05 5.4 Intake System
I have a 05 FX4 SCREW 5.4 liter and i want to increase the ponies. Any help would be greatly appreciated i was looking at a K&N system. I have a EDGE programmer in the truck. Also, would this also help the mpg? Thanks
Troy
Old Oct 21, 2007 | 08:04 PM
mSaLL150's Avatar
i have the K&N system, and its great. however if you plan to stay with the edge, i would recomend the AF1 3" or the Airraid intake systems, due to the fact that they will increase power without leaning out your engine. The other intakes (K&N included) require custom tuning to keep your engine safe.
Old Oct 21, 2007 | 11:43 PM
troy eck's Avatar
Is it
Is that system opened or boxed I live in the Seattle area lots of rain and i do love the mud.
Thanks Troy
Old Oct 22, 2007 | 01:03 AM
02CREW4x4's Avatar
AF1 is an open filter design. I installed one on my 02 5.4l about 3 weeks ago. It gave the engine a nice growl during hard acceleration. I noticed a little better throttle response, but have not been able to check if mpg increased. Unless you sink your truck, I don't think the open design will be a problem.
Old Oct 22, 2007 | 02:54 AM
troy eck's Avatar
Does it
Does it really matter on if it is a open or closed system and anyone running an 05 5.4 with a Edge system?
T
Old Oct 22, 2007 | 05:24 AM
Kevin24's Avatar
I myself would run no CAI in combination with the edge on a 3valve.
Your asking for possible problems IMO. How will you know if it's running lean?? You may find out if it runs lean enough to put it over the limit I would either leave it with just the edge or get custom tuning!! The edge can only fix a lean condition at WOT.
Old Oct 22, 2007 | 01:12 PM
mSaLL150's Avatar
T
my K&N is open box, and its fine like that. i do a love of offroading during hunting season, and it rains here too and i havent had any problems.
Old Oct 22, 2007 | 02:33 PM
troy eck's Avatar
What about
Who makes the S&B system? Anyone running a 05 5.4 with the edge.. i for the most part run the edge on stage 2. I do not want to run too lean but during normal driving is that much of a problem. Would just changing the stock L pipe and using the OEM filter box be worth it? T
Old Oct 22, 2007 | 03:30 PM
05supercrew's Avatar
S&B makes S&B, they also make the filter for AF1. I had the Edge on my 05 screw 5.4 and it worked great on my stock truck until I added a cat-back and cai then it leaned out bad. Are you looking to put an Airraid JR on? If so you wont have any problems.
Old Oct 22, 2007 | 03:42 PM
troy eck's Avatar
Cool Thanks
Well ,first off nice truck.. i do not know what i want now. i thought i was going to get a K&N but, now hell just getting info on others. I like the way a closed system is closer to the factory system but.. I will look at the jr set up and see T
Old Oct 22, 2007 | 03:47 PM
Thanks, keep reading. I must have changed my mind 20x before I just got the S&B and love it. But I wouldnt get the S&B and the Edge.
Old Oct 22, 2007 | 03:56 PM
troy eck's Avatar
Airraid Jr
Running the Airraid JR with the edge i will not have any issues...cool is there any other system that i can run with no worries? Thanks for the info
T
Old Oct 22, 2007 | 04:27 PM
T
From what everyone else is saying you can run the AF1-3'' with no problems.
Old Oct 22, 2007 | 06:04 PM
Kevin24's Avatar
I still question running either of those with the edge myself.
Ya the 3 inch AF1 is okay to run stock but not combined with the edge as far as i know.
Do what you like it's not my truck
My last suggestion to you is to call Mike Troyer or speak to Neil and ask them about that combination.
Old Oct 22, 2007 | 06:09 PM
ONE04FX4's Avatar
Talking
i have run my k&n without a tune and with. never threw any codes when running without the tune. and mine is an 04 which was prone to running lean without tuning with any intake. the airaid i first had did throw a code but the k&n did not.
