angled exit question...
Old Sep 25, 2007 | 01:44 PM
LUKE_DUKE's Avatar
Yeah, i have the same problem. No muffler shop around me can do mandrel bending. I want Magnaflow, but i want side exit exhaust.. .guess i'll have to compromise and get it made by a shop.. buy a muffler from Magnaflow, add my own tips...
Old Sep 25, 2007 | 03:31 PM
Copperhead64's Avatar
Originally Posted by LUKE_DUKE
Copperhead
Which exhaust tip did you get? Is that the actual H.D. tip or one from Magnaflow? Is that a si/do muffler?
They had this big wall with all these tips and i was overwhelmed with the quantity so i asked the shop guys opinion and he chose them for me. I had told him i wanted it HD style so he thought those were the best fit and he was right. Yes it is the SI/DO muffler
Old Sep 25, 2007 | 05:44 PM
PHS79's Avatar
Originally Posted by LaVaDog
Are you sure you guys are getting Mandrel bends? I was told from my muffler shop that the equipment to do it is really expensive and not a lot of shops are able to do it. I called around to different shops before getting mine done and none of them were able to perform mandrel bends.
Thats strange, all the shops that I know of around here do mandrel bends. The shop that did the exhaust on my work truck 9 years ago did mandrel, even way back then. Then a different shop did all mandrel stuff on my 04 last year. I guess that it just depends on where you are located.
Old Sep 25, 2007 | 07:29 PM
ian51279's Avatar
x2.
Old Sep 25, 2007 | 10:26 PM
Shocker6782's Avatar
I just installed a full stainless steel magnaflow system si/do with tips for my stx and it was only $390 shipped to my front door. Installed in about an hour.
Old Sep 26, 2007 | 11:17 AM
LUKE_DUKE's Avatar
Shocker,
Where did you order from?
Old Sep 27, 2007 | 12:34 AM
Shootermay's Avatar
cheeseman if you have a buddy thats welder friendly you can get your exhaust done for very little idk how much the muffler costs and my tips were 20$ but without the 40$ for tips my exhaust cost me around 25$ for tru duals i welded it myself but if you or one of ur buddies can run a wirefeed and a grinder with a zip disc(plasma cutter works real nice) you can get it done cheap. Just have a shop with a tube bender bend some 90s and then cut them off to what you need. i recommend going strait out the back(easier to keep the tips at the same angle)
Old Sep 27, 2007 | 05:16 PM
Luke, I ordered my set up through hottexhaust.com, I used the code someone mentioned on here and it took off like $80 plus they were having a sept. sale. It was at my front door in 3 days and was on the truck in 1 hour. It came with the maggie 18inch muffler,kinda wish i would have gotten the 14 but for now it sounds good with no drone.
